abs plastic???
Systems
Systems Posts: 14,872
edited May 2004 in Custom Fabrication
i hear of people using some thing called abs plastic(1/8") to build custom dvd consoles and stuff. Where do u buy it and how easy is it work with? I heard of people gluing and bend pieces to create a mold and then using duraglas to build shape and contours to the mold. Anyone ever heard of using this stuff??? thanks
Testing
Testing
Testing
  • [Deleted User]
    [Deleted User] Posts: 763
    edited May 2004
    HERE This place has every piece of plastic you could ever need. ABS is easy to work with and can be used in many applications. If you need a little more direction with a little higher prices try HERE
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited May 2004
    Josh, You just made my friggin year! That is the best site I have ever been to. Considering I am about to do a lot of custom work... Thank you!
    -Jerry
    -edit- the first one...
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
