abs plastic???
Systems
i hear of people using some thing called abs plastic(1/8") to build custom dvd consoles and stuff. Where do u buy it and how easy is it work with? I heard of people gluing and bend pieces to create a mold and then using duraglas to build shape and contours to the mold. Anyone ever heard of using this stuff??? thanks
Testing
Testing
Testing
Testing
Testing
Josh, You just made my friggin year! That is the best site I have ever been to. Considering I am about to do a lot of custom work... Thank you!
-Jerry
-edit- the first one...___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself.
