programming polkaudio surroundbar bass volume to tv remote
family-pits
i programmed my volume up n down to my tv remote , does any one know how to get my volume up on the bass??
i lost the original remote. i need to program with my tv remote to control the bass volume as well thanks ..
Post edited by family-pits on
Hello,
Which model SurroundBar do you have?
Regards, Ken -
Kenneth Swauger wrote: »Hello,
Regards, Ken
sorry ... it is the 3000 -
Hello,
With the SB on tap the "learn" button, on the bar, once. This puts it in the "subwoofer" mode, now tap the "volume up" or "volume down" button. That is a single tap as opposed to a continuous push. The bar will automatically come out of this mode after about 20/30 seconds.
Regards, Ken -
Regards, Ken
hey , thanks Ken , i got that now , BUT problem i am having is, if i use my remote , i cant adjust Tv AND surround sounds sepertly ...
i got tv volume under tv mode and volume bar up n down on cable mode, but seems other modes wont pick up the bass. i had bass loaded under cable but nothing else worked ? any ideas ? -
family-pits wrote: »hey , thanks Ken , i got that now , BUT problem i am having is, if i use my remote , i cant adjust Tv AND surround sounds sepertly ...
also to add , when doing the single tap for bass , do i then hit volume up on sound bar then remote as i did for the volume ?? or just single tap then hit volume on remote?
seems i cant get the bass to work
