programming polkaudio surroundbar bass volume to tv remote
family-pits
family-pits Posts: 4
i programmed my volume up n down to my tv remote , does any one know how to get my volume up on the bass??
i lost the original remote. i need to program with my tv remote to control the bass volume as well thanks ..
Post edited by family-pits on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited August 2012
    Hello,
    Which model SurroundBar do you have?
    Regards, Ken
  • family-pits
    edited August 2012
    Hello,
    Regards, Ken
    sorry ... it is the 3000
  • [Deleted User]
    edited August 2012
    Hello,
    With the SB on tap the "learn" button, on the bar, once. This puts it in the "subwoofer" mode, now tap the "volume up" or "volume down" button. That is a single tap as opposed to a continuous push. The bar will automatically come out of this mode after about 20/30 seconds.
    Regards, Ken
  • family-pits
    edited August 2012
    Hello,
    Regards, Ken
    hey , thanks Ken , i got that now , BUT problem i am having is, if i use my remote , i cant adjust Tv AND surround sounds sepertly ...
    i got tv volume under tv mode and volume bar up n down on cable mode, but seems other modes wont pick up the bass. i had bass loaded under cable but nothing else worked ? any ideas ?
  • family-pits
    edited August 2012
    also to add , when doing the single tap for bass , do i then hit volume up on sound bar then remote as i did for the volume ?? or just single tap then hit volume on remote?
    seems i cant get the bass to work
