SDA clone?
  • halo71
    halo71 Posts: 4,638
    edited August 2012
    It's not surprising at all. See the pile of crap he left in Trey's FS thread? lol
    --Gary--
  • Face
    Face Posts: 14,340
    edited August 2012
    nhhiep wrote: »
    50hz? you're joking right? with all the SDA thing, I think there are more than 2 XO points.
    Nope, and even the 50hz crossover is arguable. All the information you need is out there.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited August 2012
    nhhiep wrote: »
    Those are the specs that Polk published. I did not do any measurements to verify and I don't know if anyone else has. It is possible that there was a typo in the published specs and it is also possible that there may be "secret" crossover frequencies pertaining to the dimensional drivers. You may want to verify all this with Polk's customer service.
    The response below 50 Hz is dominated by the passive radiator.
  • evhudsons
    evhudsons Posts: 1,175
    edited August 2012
    sometimes the amazingly complex results are from the simplest implements.
  • nhhiep
    nhhiep Posts: 877
    edited August 2012
    Given the size (6.5")of the woofers, 50hz is probably as low as they can go anyway.
    I remember reading somewhere that there is another XO point at 150hz for the 4 woofers running normal signal (not SDA signal from the other side). is there any truth to this?
    BTW, I just noticed that the tweeters aren't pushing SDA signal at all according to the Sticky. If that is true, then 2 tweeters in each tower are pushing the same frequency? if not, then isn't there another XO point?
    heiney9 Posts: 25,515
    edited August 2012
    nhhiep wrote: »
    Depending on model and especially generation the x-over points and the drivers affected are different.
    Certain generations SDA the tweeter were part of the SDA signal (with the side by side tweets). Later generations with multiple vertical tweeters use what's called a "progressive point source" and each plays at a different output level combined create a single point source.
    Get your Google search on, especially and the POLK SDA website and start reading reviews as well as the Polk literature from over the years. It explains a lot of your questions, as well as several SDA threads on CP. I know it can be tedious to do the research, but if you aren't willing to put in the effort to get the info you need then maybe you should rethink the "clone". I and others are tired of constantly re-tracing all the same questions. I found the information somewhere originally, I'm sure you can too.
    Good luck
  • Face
    Face Posts: 14,340
    edited August 2012
    nhhiep wrote: »
    Driver size has very little to do with their ability to dig to a certain frequency. There are pro audio 8's that don't play below 100hz, meanwhile there are 6.5's that dig down to 20hz.
    FYI: http://www.polkaudio.com/forums/showthread.php?130994-Freq-Resp-for-MW6502-driver&p=1747515#post1747515
    pitdogg2 Posts: 27,340
    edited August 2012
    slight derail
    anyone have an idea about how low the mw6600 digs?
  • Face
    Face Posts: 14,340
    edited August 2012
    IIRC, the 6503 is the 6500 replacement, so it should be similar.
    edited August 2012
    Face wrote: »
    well yes that is correct, I'll have to check ohms on a 6600 I seem to remember they were lower ohms than listed. My sda's use 3 6600 and a 6501 for dim. anyhoo thanks Face
  • ZaPHoN
    ZaPHoN Posts: 90
    edited September 2016
    Did you ever fallow through with the experiment? The SDA's in these Troels Gravesen PMS would be interesting.
    Home Theater & Listening
    RECEIVER Yamaha HTR6180
    FRONT AMP McIntosh MC2125
    THEATER AMP EMOTIVA XPA 7
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    SURROUND LR KEF Cresta 30
    REAR Polk Monitor 5
    SUB Tannoy TS 10 Subwoofer
    NAS 20 TB Raid 3 QNAP
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
