MIT Shotgun S3.3 Cable Demo/Review Round 4
  • doctor r
    doctor r Posts: 837
    edited April 2012
    Very well presented. Thank you.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • blueboxer
    blueboxer Posts: 621
    edited April 2012
    You guys are very welcomed, but most of the thanks should go to Jesse and Gavin for getting this going again. High end cables can be like purchasing a car without a test drive, it can be a little scary, but getting a change to really get a feel for them first helps ease the mind.
    EndersShadow Posts: 17,765
    edited April 2012
    Recieved the cables Friday. Currently have 3 IC's for my fronts + center and the speaker cables on my 15's.......
    I wont say much since I have only 2 days of time on them...... but HOLY $HIT! LOTR Marathon on blu ray, FLAC via my computer...... yeah this demo was more than likely a bad idea for my wallet......
    Quick example of something I haven't heard before - LORT Fellowship of the Ring - when Frodo drops the ring in the snow and its picked up, I can HEAR the tink of the ring on the chain as it moves around......
    Hoping to get a couple folks together next week to listen to them to get their thoughts as well.....
    P.S. This is NOT my full review, just am friggin LOVING THESE CABLES... now back to the movie...
  • agfrost
    agfrost Posts: 2,498
    edited April 2012
    I slightly cringe at the thought of "publishing" an audio equipment review. I have worked hard to avoid using the words "veil" or "black," and I only suspect I know what is meant by "air," "microdynamics," and other terms I've read by listeners more seasoned (and more confident in sharing their opinions) than I. Please bear with me.
    Equipment disclosure: My 'normal' setup: Marantz DV-9500 universal player, which sends digital out to an Adcom GDA-600 DAC via coax (I alternate between a River Cable DigiFlex Gold cable and a Transparent Audio Premium digital cable). NAD 1700 pre-tuna, NAD 2600A amplifier, Polk Audio RTA-11TL speakers with RD0-198 tweeters and crossovers modded with Sonicaps (tweeter) and Dayton (MW) caps and Mills resistors. From DAC to pre I use MAC Reference ICs (palladium conductors), from pre to amp I've got MIT EXP-1. My speaker cables are River Cable StarFlex SPX. I also listen to some vinyl on a vintage Pioneer PL-610, which feeds a Cambridge Audio 640p phono preamp.
    As the father of two boys, newly minted as 9- and 6-year olds, much of my dreams of audiophilia must be tempered. As my 'listening room' is also the 'only TV room,' and 'main family hang-out room,' I can't quite set up my speakers out into the room as I might like. There's a low (7 foot) ceiling and an open stairwell that probably throws things out of balance, but all in all I've been reasonably pleased with the sound I've been able to get.
    My most recent addition was the Adcom DAC, bought from local Polkie daboyz (thanks Dave!), and it definitely brought me to a better place than I was previously--More "space", quieter background, greater clarity and separation, more low-volume weight/slam to bass notes.
    I received my package of MIT goodness and inserted the S3.3 ICs between my DAC and pre, and between the pre and amp (after hunting down my NAD literature to get the correct input impedances for each--not used to having to having swiches on ICs!). The S3.3 speaker cables were installed with some small difficulty: My rack is off to the side, and the 10ft length was only sufficient after I turned the amp sideways in the rack, and I couldn't feed the cable behind my shelves like I can with my 5-meter RiverCables. Had a heart-to-heart with my boys about what awful things would happen to Daddy's stereo, and to his children, if the speaker wires were messed with in any way, shape, or form.
    I wasn't immediately overwhelmed with an enormous difference in sound. I attribute this to two things: 1) I don't personally have the ears or the listening experience to immediately and definitively ID all changes due to equipment swaps. This has been true for me for various source, cable, and other changes in the past. 2) The interconnects were in need of some burn-in. Blueboxer didn't require them in his review (and he was the first since the AVT's became Shotgun S3.3's), and they arrived still sealed in plastic, almost like I had purchased them myself...:cool: Anyway, I left music going whether I was listening or not for the better part of two days, then was able to listen for an hour or three most evenings.
    After a week or so I was very aware of how much I was enjoying my music. Listening largely to my most familiar CDs and SACDs, it seemed that the MITs further enhanced many of the things that I had already been noting as improvements upon adding my DAC: increased sense of spaciousness, quietness of background, and enhanced bass weight and impact. Something that was apparently new due to the cables was that I was much more aware of the texture of acoustic and electric bass and guitar, giving an enhanced sense of realism and good detail in presenting the vibrato, subtle string bending or bowing. My sense was that I was simply getting more auditory information, rather than just hearing "the note."
    My hearing is quite suspect in the upper registers, so I won't be the best source for noting what's happening in the upper treble, but I was suitably impressed with the way that cymbals sounded--quite realistic, good shimmer, and they were neither emaphasized nor subdued compared to other frequencies in the mix.
    My curiosity was piqued about how I would perceive the difference upon removing the cables and going back to my normal setup, but I let that wait until it was time to move them along to EndersShadow. Returning to my more pedestrian cables proved to be more dramatic than putting the MITs in was--I was quite aware of a narrowing of the soundfield, the individual instruments didn't stand out as distinctly, I didn't feel quite as involved as I had during the demo. It doesn't sound "bad," but I'm distinctly aware that I'm not getting what I had with the MITs in system. A week later, I'm somewhat less aware of the difference, but my audio memory is good enough that I won't forget about my time with the S3.3s.
    In summary, I really enjoyed my time with the MIT demo package that's working its way around the country to the Polkies that have signed up for the program. They clearly took my mid-fi system and made it sound like...better mid-fi. I can honestly say that my modest rig has never sounded as good as it did with the MITs in place. Will I end up buying some? Perhaps some day. I hope to try out a tubed preamp of some variety first, and I've got most of my parts in hand to do the Fred/George Daniel/Brock modding of the Adcom DAC, which I'm hoping will make a significant improvement. If you're fence-sitting about getting in line for this program, I'd recommend you do so. It was a lot of fun and helped remind me that there are things I can do to make my listening even more enjoyable than it already is.
    A special thanks to MIT for making this demo possible and to Jesse, who has graciously offered to (herd cats) help keep the production rolling along.
    Happy listening.
    Jay
    Jay
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited April 2012
    Great review!
    Thanks for sharing and taking the time for that review.
    I've taken to a somewhat similar evaluation of cabling and also source material such as standard issue CDs, remastered CDs, or SACDs by not just doing a single comparison but A/B/A and B/A/B. Sometimes 'going back' can be more informative/revealing than just the one time A to B.
    Anyway.....love reading the reviews! Thanks!
  • engtaz
    engtaz Posts: 7,677
    edited April 2012
    Great review Jay
    engtaz
    edited April 2012
    Jay makes a good point in his review. Sometimes you get so used to your rigs sound, that you don't notice the changes in SQ until you remove something from the chain. Adding new gear/cables, then listening for a few weeks, really becomes more noticeable once it's taken back out. Nice review Jay, I forsee the kids manning a few garage sales this summer for dads MIT fund.
    edited May 2012
    I would like to thank the folks at MIT and F1Nut for making this demo possible. Attached is my review from my 2 week demo period. Enjoy!
  • Drenis
    Drenis Posts: 2,871
    edited May 2012
    Great review!
    Thanks for posting that ES.
    edited May 2012
    Drenis wrote: »
    Great review!
    No problem. I was extremely blessed to be a part of the demo. It was something like a year and a half in the making lol......
  • engtaz
    engtaz Posts: 7,677
    edited May 2012
    Very nice reviews. Thanks
    engtaz
  • grimmace19
    grimmace19 Posts: 1,429
    edited May 2012
    Cables are in my possession and hooked up as of about an hour ago. Listening to a few things now. I'll keep comments to myself until my trial period is over. I plan to meet up with allen the SDA hoarder sometime soon and try them in his system as well. The more unbiased I can be with actually telling the cables apart the better.
  • mufsoman
    mufsoman Posts: 640
    edited June 2012
    So here's my very un-official, inexperienced review. My demo just ended with the cables going to Grimmace next, as seen in the post above. My equipment list in my sig is still accurate. My speaker cables today are homemade Monoprice 12 gauge with Nakamichi nanners at both ends. Interconnects between the SC07 and Rotel amp are (embassarringly) a bundled set of video component cables (red, blue, green. These may be Monster, but there"s no brand markings and I bought them way too long ago to remember) and another set of bundled no name cables (very low grade). In earlier tests I did prove that the video component cables have a better sound than the other no name IC cables, so the video component cable set is used for L-C-R. There was a definite sound difference to the front sound stage when I swapped the component cables in. The other cables are used for the surrounds.
    OK, so now that the stage is set, let's get to the MIT's. First, these are some serious cables. One of the earlier reviews referred to the speaker cables as garden hoses, and that description is very accurate. Considering my cheap homemade cables, these things are a semi-trailer truck compared to a Smart car. I first installed the IC's and played my usual comparative song track on the old Sherwood TT, Hotel California, and noted an improvement in the sound quality/sharpness. However, once I swapped in the speaker cables too, the improvement in sound quality was much more noticeable. Not a night/day, slap in yo face difference, but just noticeable improved sound quality. Bass was tighter, highs were crisper. Symbols lingered on longer, guitar strumming was heard better, voices were more clear, etc.
    Over the next two weeks, I also watched as many movies as possible with some of my favorite HT demo scenes like Terminator Salvation opening credits and initial scenes, Incredible Hulk university attack (with the sonic cannons), etc. Sound was definitely more clear and concise all around.
    I was very anxious for this test of my low end cables vs. high end. Truly an opposite ends of the spectrum comparison. Don't know if I'll ever get around to spending $2000 on cables, but this demo has definitely proven to me that cables do make a difference (not an attempt to start another debate, just expressing my opinion based on the demo). Going back to my current setup was not disappointing, but definitely motivates me to make improvements to keep pushing the quality level. Thanks again to Jesse and MIT for this opportunity!!!
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime Pinnacle towers, Ultra center channel and Prime bookshelfs (side surrounds)
    Atmos: Polk OWM3 x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • doctor r
    doctor r Posts: 837
    edited June 2012
    Nice review. Cables do provide incremental changes in one's system and some improvements can be found for less than the $2,000 the MIT set would cost (though they are an excellent choice).
    rack Adona Eris 6dw
  • engtaz
    engtaz Posts: 7,677
    edited June 2012
    Good review. Thanks for sharing.
    engtaz
  • grimmace19
    edited June 2012
    Warning: The following review may be controversial to some members of the forum.
    To begin my review I want to lay out exactly what's in my system and how it's hooked up. This will allow a better understanding of the swaps I did with the cables and the comparisons I was able to make.
    Polk LSI15s, LSIC, LSI9's for my 5 channels.
    Emotiva UMC-1
    Adcom 5802 for the L+R and a GFA 7500 running the center and rears
    Marantz dv-9500 sacd player w/ 5.1 output
    Squeezebox touch
    The interconnects for the amps are MIT Terminator 2 cables with the grey ribbed boxes. I also have them connecting my marantz player in 5.1 direct mode.
    My squeezebox is hooked up with Transparent "The Link 200" cables.
    My speaker cables for the fronts are MIT Terminator 2 bi-wired cables. Grey with the ribbed boxes and tech flex (one of the newest versions if I'm not mistaken).
    To begin, unboxing these monsters was exciting. I have been waiting to demo these for a LONG time and when I was just about to get the last pair, I moved myself to the back of the list because I was going to be on vacation when I was due to get them. It worked out in the long run because I got to test these instead. The one minor change I had to make in my rig was to put the brass plates back into the binding posts to use the single ended cables instead of my current bi-wire cables. I hooked up a pair of interconnects first to my squeezebox and played some different music through Spotify and thought I heard "some" change. Nothing really stood out to where the change came from but overall it seemed the music "might" have sounded a little better. The next step was to get the speaker cables into the mix. When introducing these I noticed nothing. I played the same tracks as earlier through the squeezebox and didn't hear any change. I believe this was likely due to the limited SQ of the spotify stream. Even though I pay for the service and get the higher quality stream, I realize it is still limited in it's quality.
    Now for the serious comparison. I took one pair of interconnects and hooked them up to my 5802 and into the emotiva. I took the other pair and hooked them up from my marantz player into the emotiva, and of course kept the speaker cables hooked up. The nice thing about my player is that it outputs the same signal in both the 5.1 outputs and the stereo rca connections at the same time! All I need to do to switch the signal is change inputs on the emotiva which goes very quickly so there is only a slight delay in the signal when it switches interconnects.
    My music selection varied for the testing and included:
    Wish you were here on SACD
    Dark side of the moon SACD
    Sea Change by Beck regular cd
    Dave Matthews - Crash regular cd
    Beatles Love on DVD-a and regular cd (double pack)
    O.A.R. - Risen regular cd
    I definitely listened to more as my two weeks went on, but these selections were the main ones during the main listening session after first hookup. I have heard all of these albums dozens of times and am more than familiar with all of them.
    My first impression to everything when using the input that used all the interconnects and speaker cables at the same time was that I didn't notice ANYTHING. Though the sound was pleasant, I really like what I have for a system but, couldn't notice a thing. After trying and trying to hear something, nothing stood out any more than before. After a run through of some key songs on those albums, I began doing a swap of inputs where it would take the interconnects out of play that were going from the player into the emotiva. I switched back and forth trying to see if I could hear anything between the Terminators and the Shotguns, again I was stumped and disappointed. No changes were noticed on any tracks in any way by me.
    A lot of people have said that they notice the change after the cables were in their system for a while but I am sad to report that I didn't notice any positive or negative changes in my system as my two weeks went on. I watched about 10 movies throughout the demo period and didn't pick up on anything either.
    Now, because I was disappointed to not hear any changes (or didn't think I did) I unplugged all the Shotguns from my system this afternoon and went back to exactly as things were before they arrived at my house. I again unfortunately was left disappointed that everything still sounded the same. I suppose this is a bitter-sweet realization however that in my rig with my gear, better cables don't seem to offer improvements for me.
    I am still definitely a cable believer however. The improvements I noticed going from my audioquest g-snake cables when I first started to the MIT's I run now was tremendous with my wife and a few friends saying they could also tell it sounded better. This was an amazing opportunity to demo these cables for just the cost of shipping. I'm glad I participated for such a low price of admission. However, I wouldn't upgrade my current cables for anything further up the totem pole with the gear I have in play. Thanks to everyone at MIT and Jesse for making things like this happen here.
    OMG I JUST REALIZED MY ISSUE!!!! I HAVE AN EMOTIVA PRODUCT, NO WONDER I DIDN'T HEAR ANYTHING AS IT ALL SOUNDS LIKE CRAP TO BEGIN WITH!
    - only kidding guys, just wanted to poke fun at that issue before some other bastage makes the comment themselves.
  • BlueFox
    BlueFox Posts: 15,250
    edited June 2012
    Toolfan66 wrote: »
    I have one question Nick, did you set the impedance switch's on the interconnects to match your gear? I'm sure you did but thought I would ask..
    That is a good question. I experimented one night with my S1.3 XLR ICs and each time I set the switch to the wrong value the soundstage collapsed, and the sound became dense, for lack of a better word. The correct setting does matter.
    edited June 2012
    Nick I am honestly NOT surprised you didnt hear much of a difference considering your running MIT cables already and transparent cables as well (very similar sound to MIT). Your probably much more accustomed to their sound and your cables are pretty close to their level of performance if I remember correctly based on where they were in the old MIT lineup.
    For me the biggest difference was NOT in the IC's but rather in the speaker cables since I didnt have MIT speaker cables. You already had MIT speaker cables, so you are familiar with their sound.
    I personally appreciate your honesty. There is room for everyones opinion when it comes to cables, provided you have actual experiences to reference rather than just something you read online once :biggrin:
  • grimmace19
    edited June 2012
    I did toggle the impedance a few times throughout the week with the same results. I figured (maybe a bad assumption) that it wouldn't matter much in regards to the changes. Maybe I wasn't listening "critically" enough to tell what happened with them. All in all, I am sure they are top notch cables, but you also need pretty top notch stuff to run them with.
    Larry, I can attest to the magic of your system and understand that you likely did notice a huge improvement when adding those into the mix. As for me, I'm starting a quest that will hopefully end in a pair of kef reference 201/2's in the next year or so provided things go smoothly in my life. Maybe then the shotguns will matter for me. As for now, the review speaks for itself.
  • zingo
    zingo Posts: 11,258
    edited July 2012
    Cables are in the system and warming up. Comments to come shortly.
  • Outfitter03
    Outfitter03 Posts: 563
    edited July 2012
    Thank you to Jesse and MIT for allowing me to demo this excellent set of Speaker Cables and Interconnects. I started my audio journey about two and a half years ago with the purchase of the Monitor Series of speakers for home theater. I have monitor 70s and CS-2 in the front, Monitor 60s as surrounds and Monitor 40s in the rear. Fortunately I found this website in the middle of my purchase process the first summer and bought a Parasound 1200ii power amp for the 70s and a Adcom 545 to power the 60s prior to my AVR arriving. I use my Yamaha 2065 to power the rear channel 40s.
    My apartment viewing room is 20?X40? and the TV is set up on a 20? wall with about 15? of usable space due to a doorways. For the money that I spent I have been extremely pleased so far with my purchases.
    I use my system about 50% of the time for TV/Movie and 50% for music. Unfortunately I do not have the space to set up a dedicated two channel system, so initially I started music listening with my AVR in Pure Direct Mode. I have recently upgraded to the Dared which easily fits into my humble component cabinet. This requires manually switching interconnects when listening to two channel music, but the result is worth the effort!
    I installed the MIT interconnects and had those in my system for the 10 days of this demo. Due to my speaker placement I had to move my speakers to accommodate the 8? speaker cable lengths and experience the whole setup (with cables) during a 6 hour one day listening session.
    My music selections included: Rolling Stones, U2, Dire Straits, James McMurty, Neil Young, Grover Washington jr., Tom Scott, Norah Jones, Sade, Loreena McKennitt, Sinead O?Conner and Cowboy Junkies.
    The MIT interconnects made a large difference in my system. Being relatively new to audio I don?t know if I have a mastery of vocabulary to describe the changes, but I will do my best. The lows were definitely extended down and the bass out of the monitor 70?s was more pronounced and clear. The weighting of the frequencies was very pleasing and seem to fill out the music across all spectrums. The impact was improved, about an additional 20% over the change that I saw with the addition of the Dared. My setup has never really been fatiguing, but I definitely was motivated to listen to the music longer.
    The day that I listened to the speaker cables the performance was improved further, although my experience said that I picked up about another 30% of goodness from the change. I did not switch back to the old interconnects while running the MIT speaker cables.
    I am about 2.5 years away from moving to a new home that will have the space to set up a dedicated two channel system . For the new system I need to have better speakers and am currently shopping locally for SDA?s to purchase and modify. I am sold on this model of MIT interconnects and Speaker cables and if funds allow will be purchasing two sets of interconnects in the next year.
    If I were to rate the impact of my upgrades so far they would be: Dared SL-2000a with the right tubes over AVR (Huge), Future upgrade to MIT S3.3 cables (Large), Upgrade of Denon 2900 to OPA627 opamps and upgrade of output capacitors (Medium), upgrade of source from PS-3 to Denon 2900 (Medium) and upgrade to Signal Cable Magic Power Cord for Power Amp (Significant).
    Thanks again Jesse for the opportunity to participate in this Demo and thanks to the forum members who are willing to share and discuss all things audio. I love going to the website and learning about ways to extend my wish list for the future!
    Sig:biggrin:
    System Components:
    Denon 2900 Modded with OPA 627 opamps and clarity ESA output capacitors. (Video Card Removed).
    Dared SL2000A. Gold Board, Chinese input and output capacitors. Brimar rectifier and Amperex SQ signal tubes.
    Parasound 1200ii Power Amp.
    Polk Monitor 70
    Audioquest Diamondback and Copperhead interconnects.
    Speaker Cables: Biwired with Audioquest Indigo for tweeters and Monster Cable Powerline 2 for mids and bass.
    edited July 2012
    Glad your getting first hand experience on what a good cable can bring to the table. Even just a relatively budget power cord like the Magic can make an improvement as it so has on your amp. Happy listening.
  • zingo
    zingo Posts: 11,258
    edited July 2012
    Cables shipped today to next reviewer. Review to come shortly.
  • kcoc321
    kcoc321 Posts: 1,788
    edited July 2012
    damn, which I had realized these where out here ;)
    F1nut Posts: 52,406
    edited July 2012
    kcoc321 wrote: »
    You seem to meet the basic requirements, so if you'd like, I would be happy to add your name to the list. Just send me the required info via PM.
    Folks, I should mention that the person in possession is not allowed to lend out the cables and the list is strictly followed.
    F1nut Posts: 52,406
    edited July 2012
    Update:
    Gimpod has asked to be removed from the list.
    indyhawg has asked to moved down the list.
    Is there anyone that would like to be added to the list?
    edited July 2012
    Depending on timing I might be interested in another try, assuming thats allowed as I will hopefully in the next month or so have a better 2 channel amp for my LSi's.....
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2012
    Update:
    Are these any different from my shotgun s3's ?
    F1nut Posts: 52,406
    edited July 2012
    "Blue - those folks are done with the cables and now have the blues, which can only be cured by purchasing a set of MIT cables."
    Time to get your wallet out. :cool:
    F1nut Posts: 52,406
    edited July 2012
    leroyjr1 wrote: »
    Yes, they have a .3 in the name. :wink:
    Actually, the new S3.3 is closer to the previous S2's
