Bad Speaker?
wingnut4772
One of mr rear surrounds is making a buzzing noise. I think I remember reading somewhere that if you gently push in the speaker and it makes a crunching noise it's toast. Is that right? It only makes that noise on one side when i push it in.
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
Sounds like you have a blown voice coil to me if it makes a rubbing or scratching noise when you press in the cone. If the tweeter is still good all you would need is a replacement woofer.
That's what I was afraid of. I mean it still sounds ok just has that occasional buzz at certain frequencies. What would cause that?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
That is the nature of voice coil rub. Certain frequencies and levels of sound will make itself known:)
Oh well. ****.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
I am gonna get my speaker fixed but I want to avoid doing it again. I have both of the Totem Mask 6.5 in ceiling speakers hooked up to a Parsound HCA 1000a. I use them as my rear surround in a 7.1 configuration. My remaining speakers are run by a Parsound 5250 amp - including 2 more Totem Mask 8" side surrounds which I have no issues with. The HCA 1000 is 100 watts per channel and the 5250 is 250 watts per channel.
Is the 100 watts per channel not enough for the Totem Masks? They are pretty efficient but 6 ohms.
Note: I believe both rear surrounds to be affected.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Unless you play your system at ear splitting volumes I would think that's enough clean power. Surrounds in an HT set up don't carry too much of the load, and that amp should put out more than enough clean power.
Just googled you HCA 1000a and here are the specs. Nice little amp:
FEATURES
Circuitry designed by John Curl
THX Ultra-certified
Direct Coupled -- no capacitors or inductors in signal path
Input stage uses hand matched complementary JFETs
12 beta-matched 15 amp, 50 MHz bipolar output transistors
785VA Toroid power transformer with independent secondary windings for each channel, 40,000 ?F power supply filter capacitance
Independent power supplies for each channel
DC Servo and relay protection circuits
Highbias Class A/AB operation
AC present, standby/normal, current overload indicators
Tiffany-style RCA input jacks, loop output jacks
12 volt DC automatic turn-on circuitry
Gold-plated 5 way speaker binding posts
Custom designed removable IEC AC cord
Rear mounted gain controls; ground lift switch
2 rack space height front panel
Rack mounting adapter available
SPECIFICATIONS
Continuous Power Output - Stereo:
125 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, both channels driven;
200 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, both channels driven
Continuous Power Output - Mono:
400 watts RMS, 20 Hz - 20 kHz, 8 Ω
Current Capacity:
45 amperes peak per channel
Slew Rate:
>130 V/?second
Power Bandwith:
5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total Harmonic Distortion:
< 0.03% at full power; < 0.01 % typical levels
IM Distortion:
< 0.03 %
TIM:
unmeasurable
Dynamic Headroom:
> 1.5 dB
Interchannel Crosstalk:
> 80 dB at 1 kHz; > 60 dB at 20 kHz
Input Sensitivity:
1 V for 28.28 V, THX Reference Level; 1.1 V for full output
Input Impedance: 33 k Ω
S/N Ratio: > 116 dB, full power; > 96 dB, THX Reference Level
Damping Factor:
> 800 at 20 Hz
Power Consumption:
500 watts
Dimensions:
w 17 1/4" x h 3 1/2" x d 13 1/4", h 4 1/8" with feet
Net Weight:
22 lb"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I wonder if HT system isn't balanced correctly, I can't see the surrounds getting such a volume to blow a woofer.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
