Bad Speaker?
wingnut4772
wingnut4772 Posts: 7,519
edited July 2012 in Troubleshooting
One of mr rear surrounds is making a buzzing noise. I think I remember reading somewhere that if you gently push in the speaker and it makes a crunching noise it's toast. Is that right? It only makes that noise on one side when i push it in.
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
  • Conradicles
    Conradicles Posts: 6,119
    edited July 2012
    Sounds like you have a blown voice coil to me if it makes a rubbing or scratching noise when you press in the cone. If the tweeter is still good all you would need is a replacement woofer.
  • wingnut4772
    edited July 2012
    That's what I was afraid of. I mean it still sounds ok just has that occasional buzz at certain frequencies. What would cause that?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Conradicles
    edited July 2012
    That is the nature of voice coil rub. Certain frequencies and levels of sound will make itself known:)
  • wingnut4772
    edited July 2012
    Oh well. ****.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • wingnut4772
    edited July 2012
    I am gonna get my speaker fixed but I want to avoid doing it again. I have both of the Totem Mask 6.5 in ceiling speakers hooked up to a Parsound HCA 1000a. I use them as my rear surround in a 7.1 configuration. My remaining speakers are run by a Parsound 5250 amp - including 2 more Totem Mask 8" side surrounds which I have no issues with. The HCA 1000 is 100 watts per channel and the 5250 is 250 watts per channel.
    Is the 100 watts per channel not enough for the Totem Masks? They are pretty efficient but 6 ohms.
    Note: I believe both rear surrounds to be affected.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • drumminman
    drumminman Posts: 3,396
    edited July 2012
    Unless you play your system at ear splitting volumes I would think that's enough clean power. Surrounds in an HT set up don't carry too much of the load, and that amp should put out more than enough clean power.
    Just googled you HCA 1000a and here are the specs. Nice little amp:
    FEATURES
    Circuitry designed by John Curl
    THX Ultra-certified
    Direct Coupled -- no capacitors or inductors in signal path
    Input stage uses hand matched complementary JFETs
    12 beta-matched 15 amp, 50 MHz bipolar output transistors
    785VA Toroid power transformer with independent secondary windings for each channel, 40,000 ?F power supply filter capacitance
    Independent power supplies for each channel
    DC Servo and relay protection circuits
    Highbias Class A/AB operation
    AC present, standby/normal, current overload indicators
    Tiffany-style RCA input jacks, loop output jacks
    12 volt DC automatic turn-on circuitry
    Gold-plated 5 way speaker binding posts
    Custom designed removable IEC AC cord
    Rear mounted gain controls; ground lift switch
    2 rack space height front panel
    Rack mounting adapter available
    SPECIFICATIONS
    Continuous Power Output - Stereo:
    125 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, both channels driven;
    200 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, both channels driven
    Continuous Power Output - Mono:
    400 watts RMS, 20 Hz - 20 kHz, 8 Ω
    Current Capacity:
    45 amperes peak per channel
    Slew Rate:
    >130 V/?second
    Power Bandwith:
    5 Hz - 100 kHz, +0/-3 dB at 1 watt
    Total Harmonic Distortion:
    < 0.03% at full power; < 0.01 % typical levels
    IM Distortion:
    < 0.03 %
    TIM:
    unmeasurable
    Dynamic Headroom:
    > 1.5 dB
    Interchannel Crosstalk:
    > 80 dB at 1 kHz; > 60 dB at 20 kHz
    Input Sensitivity:
    1 V for 28.28 V, THX Reference Level; 1.1 V for full output
    Input Impedance: 33 k Ω
    S/N Ratio: > 116 dB, full power; > 96 dB, THX Reference Level
    Damping Factor:
    > 800 at 20 Hz
    Power Consumption:
    500 watts
    Dimensions:
    w 17 1/4" x h 3 1/2" x d 13 1/4", h 4 1/8" with feet
    Net Weight:
    22 lb
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2012
    I wonder if HT system isn't balanced correctly, I can't see the surrounds getting such a volume to blow a woofer.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
