HK Bi-Amping - First Impressions
OK, I've had a chance to listen to excerpts from a few more action movies (thanks to my DTS Demo disk) to check out the bi-amping of the center channel. I'll say right off the bat that the difference is not a dramatic one. I was listening for greater depth in the dialogue, especially during busy action scenes. I was also listening for detail and a broader front stage. What I found was slightly more detail, more syllabence (sp.), a bit more dynamic presence. There was also a noticeable increase in bass during action scenes.
Overall, there isn't a "knock your socks off" difference for movies. Since I don't listen to music in surround sound, I didn't check that out. However, I would surmise that the difference would be greater for music listening. I may need to do some tweaking and let the amp burn-in, and I may hear more improvement over time.
My recommendation would be to pursue bi-amping your center channel, but it should be considered a nice tweak once you've exhausted other methods for upgrading your sound (good speakers, nice receiver, high quality sources, placement optimization, interconnects, Hsu or SVS sub, bi-amping the fronts, etc.). To me, it was worth the money I spent ($197 plus shipping for a NIB HK amp -- 200 watts feeding the center channel).HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Earlyb, did you pick it up at onecall?
While on the topic of adding amplifiers, I was wondering why manufacturers mostly put preamp outs on more expensive models and not the entry level units?Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
So how do you have the amp hooked up to the center?
Guys, a little question...
I'm planning to run 5 * RTi70 for my surround sound. Should I invest in this 5*80W Carver amp to help out my H/K 7200 or would the 100W be enough for a RTi70? 16-46PCi from SVS will handle mos t of the bass.
http://ww2.onecall.com/About_00001000_22_68_0_24_0_0.htm -
100WPC of HK power is plenty for the RTi70s, but at the price on the Carver...you might as well pick it up as well...Originally posted by Sami
Absolutely!!! Get the Carver amp and bi-amp all five speakers.Earlyb, did you pick it up at onecall?
Yes. Great prices and outstanding customer service. They even called me yesterday to ask me if I had any questions about my amp.So how do you have the amp hooked up to the center?
The highs on the center channel are hook into one channel and the lows to the other channel.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Early,
Any update on how you like the Center Bi-Amp'd, or do you need more time with it?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Ok, if I get that Carver (Class A BTW), I'd probably be even better running it to highs and let the H/K handle the lows. How about configuring it, is it just plug-and-play or do I have to adjust the volume to match each other?
Jesus Christ a 5 ch 80WPC Class A amp!!!Originally posted by Sami
If that thing's really runnihg 80 WPC of Class A power into 5 chanels it's got to be a monster...That thing's gonna need lots of juice and is going to run hotter than the blazes of hell...
I have to question the Class A claim a bit at that power and price point, maybe it's some type of proprietary version of Class A, maybe Class AB or something... -
"input circuit topology that operates in constant Class-A mode"
http://www.onecall.com/PID_23715.htm
That sucker is huge. -
Oh I saw the info on that page, just questioning it a bit...Originally posted by Sami
So should I get it?Originally posted by Polkmaniac
Still need to find another pair of RTi70's to complete the surround system. That and the Carver would set me back another $600. -
Actually maybe the 'input circuitry' does operate in Class A mode, but that's only half the story...Originally posted by Sami
The whole idea behind Class A is having the input and output stages open at the same time all the time so that you have a steady flow of 'juice' at all times, as opposed to switching circuitry which basically turns each on and off repeatedly...This is why these things (Class A amps) run really hot and use lots of juice, becuase it's having to 'maintain' a constant flow of current.
I'm sure that it has "input circuit topology that operates in constant Class-A mode", but I don't think that qualifies it as a true Class A amp...I think they just stick that in there becuase people will see Class A and think "Coll Class A is good"
Anyway, I'm sure it's an awesome amp and have been contemplating purchasing one myself...just curious on the Class A statement...
Hell, maybe it is Class A and I'm just way off base... -
Yeah sure, it's still a bad **** amp...most of the amps on the market I doubt are true Class A...Originally posted by Sami
So should I get it?
I'm considering purchasing the Carver amp myself. I'd hook up my rears and surrounds with it.
Really don't need it right now, but since it's such a great deal, I could certainly use it in the future when I go to separates for HT.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Pm,
You are correct. That Carver is not a pure class A amp.
Still looks to be a pretty sweet deal.More later,
Tour...
Vox Copuli
Well, glad to see I'm not losing my mind...Originally posted by Tour2ma
Pm,
Still looks to be a pretty sweet deal. -
From what I know about Amps all low level signal areas are Class A. Thats "A" in the amp's input side of things. Like all pre-amps are class A, it's a design where 1 transistor can be used in the signal with the least noise produced. I wish manufactures wouldn't try to confuse people with these deceptive marketing phrases.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
UPDATE -- I went into the receiver's setup menu and changed the levels on a couple of the speakers. Then popped in The Last Samuri. Made a sizeable difference. The bi-amped center channel began sounding more "theater-ish". Deeper bass in the voices. More powerful presence. Well worth the investment.
Moral of the story -- don't rely too heavily on auto-calibration.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I imagine companies put preouts on their more expensive models because those who buy more expensive receivers probably wish they had the money for preamps/amps. Anticipating that the customer will probably someday want to add amplifiers especially if he picks up powerful speakers, adding preouts to a highend receiver guaranttes that that receiver will stay in that person's house. If you put preouts on a low end receiver they probably wouldn't be used because the amps would be bottlenecked by the processing in the low end models.
Just my.02%
