Large/Small question
billmich
billmich Posts: 19
edited July 2012 in Speakers
for my surrounds, which are FX500I's. I have always set these surround channel speakers to "small"
With the new receiver I am purchasing (Yamaha A3010), the manual says that when selectin g a speaker size, use LARGE for anything that has a woofer diameter greater than 16cm (6.25") and small for anything under that
the woofer for the fx500i is 6.5" (165cm)...so its over, just barely over that threshold
has anyone else here ran these using large, can they handle the lows well enough?
Main L/R= RT800I
center: CS400I
surrounds: FX500i
surround back (center): CS245i
sub= psw450
front presence : RT25i
Current receiver : Yamaha RX-V3000 (all above equipment purchased in 2000) 6.1 +Front presence
I'm upgrading to 11.2, surround back will be removed...
new surround back: TSI200
new back presence: TSI100
new sub: PSW125
New Receiver: Yamaha RX-A3010
7.1 (11.2)...
Post edited by billmich on
    txcoastal1 Posts: 13,503
    edited July 2012
    Setting AVR's for large and small has to do with crossover settings and having a sub in your system.
    If you have a sub the setting would be small directing the lower frequency output to your sub
    Setting to large and not having a sub runs speakers full range
  • Denon Frank
    Denon Frank Posts: 130
    edited July 2012
    You should fill out your signature to get a better (more accurate) response. Do you have a subwoofer in your system?
    Frank
    Polk LSiM 703 mains on Skylan Stands
    Polk LSiM 704c center
    Polk FX500i surrounds
    Parasound 5250 Amp
    Oppo BDP-105 :smile:
    SVS PC Ultra tuned to 16hz
    Panasonic 65" Viera Plasma
  • billmich
    billmich Posts: 19
    edited July 2012
    i know what large and small do, as I currently am running a 6.1 set up; I was asking if these speakers handle the LARGE setting well..
    I currently have RT800i for my mains and a CS400i for my center, and even though I have a sub, I DEFINITELY keep those at a large setting; I just don't subscribe to the theory that you set ALL speakers to small (no matter what), if you have a sub hooked up...
    Main L/R= RT800I
    center: CS400I
    surrounds: FX500i
    sub= psw450
    new sub: PSW125
    7.1 (11.2)...
  • billmich
    billmich Posts: 19
    edited July 2012
    test ...signature
    Main L/R= RT800I
    center: CS400I
    surrounds: FX500i
    sub= psw450
    new sub: PSW125
    7.1 (11.2)...
  • rooftop59
    rooftop59 Posts: 8,121
    edited July 2012
    I generally consider a full range or large speaker one that is more or less flat to about 35 hz. In other words it an handle the low E on a bass guitar and most kick drums reasonably well. Those speakes CANNOT do that, so they are not full range. However, it comes down to what to what sounds best to you. Try it both ways with a surround and bass heavy track like the Dark Knight and see which one you like better.
    I also ran a cs400i full range for a while, and it definitely bottomed out. My center now has almost the same range as that one, and I run it through the speaker level ins and outs on a small sub and cross in over at about 75hz. When I play something like DK, that little sub goes NUTS. There is no way that center could handle the full range. So I would suggest crossing over at 60hz (that is what I settled on with mine) and see what you think.
    Peace.
    Game Room 5.1.4:
    Bedroom 2.1
  • Denon Frank
    edited July 2012
    I've had the fx500i's in my system for a long time. I set my speakers to small but cross them over at 60hz instead of 80hz. Find something that puts alot of bass into the surrounds and let your ears decide.
    Frank
    Parasound 5250 Amp
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited July 2012
    I had some conflicting opinions about this also.This is going to sound stupid but w/o going into the set up I forgot which way they are set.Klipsch said one way and Yamaha said another and now and I'll get back to you later about the setting. It sounds really dialed in w/ the sub really active and all 5.1 speakers are working fine w/o clipping or any distortion ever. I few years ago I had a clipping problem w/ the rx-v665 but was resolved when I took it out of an enclosed rack and into the open and it's never clipped again at any volume level.So I just checked the speaker settings and all are on large ,and yes these are Klipsch smalls ,go figure.
  • bencorn
    bencorn Posts: 49
    edited July 2012
    I just run smalls all around and let my sub do it's job with the lows and let the speakers handle all the mids and highs. I think THX recommends this don't they? I could be wrong.
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited July 2012
    Another Data point if it helps...
    Room is ~900sq ft, 34x17' speakers/subs in middle of long wall,
    Yamaha YPAO wanted all the speakers (in sig) set to large, subs set at -9.0, crossed at 40hz. While my ears didn't agree with some of the higher frequency crossover settings, I can't seem to improve on the speaker size, sub, or crossover settings.
    Though occasionally for music, dance, techno, R&B, the stuff that's fun with too much bass, I'll bump the crossover to 80hz for some added depth (added bump) at the expense of accuracy. For critical listening stuff, subs stay off, mains to full range.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • rukawakaide1721
    rukawakaide1721 Posts: 6
    edited July 2012
    my set up are all set to small speakers at 80hz....with sub DSWPRO 660wi...watching movie was great....:biggrin:
    RTi A9
    CSi A6
    FXi A6
    DSW Pro 660wi...
    I was advice to set all speakers to large because A9 woofers can handle the lows without problem....I can say my friend was right.....But I want to use the sub also that is why I decided to set to small speakers...
    RTi A9 - Front
    CSi A6 - Center
    FXi A6 - Surrounds
    DSW Pro 660 wi
    Marantz AVR SR 6006
    WD TV Live
    Planning to add: Emotiva XPA 5...
  • 20hz
    20hz Posts: 636
    edited July 2012
    one thing to keep in mind , when you put rears and center on large it takes low end from the mains to get that bass , and that takes away rumble from the movie experiance .
    So for me I run the mains on large the rears and center on small with that my sub does ALL the needed rumbling .
    My sub is coming off the mains through a electronic crossover that splits it up around 80 hertz , the mains are polk moniter 5 .
    I realize your question but the best option is to try differant settings untill you find what sounds best , you wont scatter your 6.5" rears but you may a distortion in the mids , I figure not likely because any rear signal is but a few seconds and unless you got 200 watts going back there at full volume should be okay .
    I figure if you notice anything it will be less bass up front if the rears are on large .
    billmich wrote: »
  • pearsall001
    pearsall001 Posts: 5,249
    edited July 2012
    Here's a great article on the Large/Small setting question. I've tried it many different ways with different speakers (LSi15's with matching center & surrounds were last before my KEF's) & the Small setting XO at 80Hz always produced the best sound. Your mileage may vary so try it different ways & go with what sounds best to you. http://www.ecoustics.com/electronics/products/articles/128214.html
  • Willow
    Willow Posts: 11,223
    edited July 2012
    Intersting article. I wonder what the difference is if speakers are set to large but we control the xover say 60 or 80 doesn't that right there make the speaker size selection moot?
  • mantis
    mantis Posts: 17,325
    edited July 2012
    In a home theater setup , all speakers should be set to small regardless of the ability of each speaker. Crossover points can be adjusted in many pre's and avr's o suit said speaker package. If only one crossover point can be selected , select the lowest point of the weakest speaker which usually will be the surround channels.
    With that being said the surround speakers should perfectly match all channels in ones system IF they are looking for the best possible experience. In a perfect world the same speaker would be used for all channels.
    Tips:
    Honestly there are very few speakers on the market that are full range.So what happens when you try and run large to a speaker that can't play full range , those frequencies don't get replayed. What most need to understand is you have a replay system and you want to replay the source material as accurately as possible.
    Another really good reason to set all speakers to small is to preserve dynamic range. When you take the demand off your amp to have to play full range , it frees up capacitor energy. This in turn will yield more accuracy. For those who don't know what a capacitor is , its like a battery inside your amp with energy to change volume when the signal from the source or Blu ray for an example says"make it louder". Your volume control stays the same but the volume goes up for a period of time like when glass breaks , a car crash , gun fire etc. When you run speakers in large , some amps struggle a bit and ask the capacitor to help out with the load even under normal conditions. So when louder is required , your capacitors don't have a full charge and therefore cannot accuracy track the increase in volume necessary to replay the sound correctly. I could go into more detail but thats the extreme short version. Look up capacitors and go read up on them for a deeper understanding. I'm sure there is info in here somewhere about them.
    Yet another reason to run your speakers in small is a lot of speakers sound clearer running less frequencies even if it's less then what they actually can do. Sometimes they sound more natural , more alive and seem to breath REAL life.
    When building a theater system , make sure you spend a good amount on a subwoofer or 2. This is where the real magic happens and really makes a good system it's best. Cheap out on your subwoofers and always have a so so system. Even entry level system will benefit from good quality woofer.
    Dan
