Need help with buzzing noise
Hey fellas, I bought a $39 Monster power strip with coax protection. I'll be darned if the thing eliminated 95 percent of the noise. The noise can now only be heard if my ear is within a foot of the tweeter. Seems like a bit of a band aid fix, but I will take it.
Cooljazz- I will unhook above power strip tomorrow and lift that ground. If that eliminates the problem, what is the next step? A better grounding point? Better wire? It has to be grounded, right?
Thanks again for everyone that helped!!! JamesOnkyo Pr-sc 5509
Parasound 2250/Parasound 5125
SVS PB 12 Plus
Denon DBP-2012 Bluray
Polk RTI 8, CSI 3, 4 FXI 3
Sony 55" LCD -
So I guess you were a good candidate for a power conditioner. Still, you have a grounding issue somewhere in the chain. Maybe pickup a few more cheater plugs and play around with different pieces or combinations. A cheater plug in essense just lifts that ground to whatever it is added on to.
Glad your close to getting it fixed altogether anyway, rock on.HT SYSTEM-
lsi 9's -
I can see the light at the end of the tunnel! Thanks again!Onkyo Pr-sc 5509
SVS PB 12 Plus
Sony 55" LCD
