Problem with pioneer VSX-81TXV
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited June 2013 in Troubleshooting
So I have been very busy, a few weeks ago I finally got to sit down and watch a few movies. I noticed at the end there was no rears. Today I investigated this further.
7 Channel stereo regardless of input "no rears"
DVD or BR no rears during movies
Receiver setup can get pink noise going to the rears no problem.
What am I missing? :eek:
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • bigaudiofanatic
    edited July 2012
    Bump
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited July 2012
    Anyone?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
    edited July 2012
    Did you have 7.1 before? Or is it possible that this is the first time you've noticed nothing is coming from back there. I know some Pioneers have a menu where you can select from 2.0 to 7.1. Have you checked that menu? That's all I can think of if you're actually getting pink noise from back there, the amp section must be working!
    Maybe someone who knows that particular unit can chime in here! Hint! Hint!
    cnh
  • bigaudiofanatic
    edited July 2012
    cnh wrote: »
    cnh
    I am not running 7.1 just 5.1, yes I have always noticed that my rears have worked especially with action scenes and concerts.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • mantis
    mantis Posts: 17,544
    edited July 2012
    So let me get this straight , you can test tone your surround channels but don't get anything when watching a movie or TV show?
    Just to be clear
    Are your surrounds wired to the surround channel outputs or surround back outputs?
    Is your setup set to 5.1?
    Is your source in PCM?
    Is your source set to Bitstream?
    If all setup and wiring is correct , what about Auto decoding? Are you locked in stereo or direct mode and didn't check if your in Auto surround or 7 channel stereo? Pioneer actually calls this mode EXT.STEREO which will play audio from all channels all the time.
    IF everything is correct then the processor is not working correctly and needs to be repaired or replaced. With the age of the 81 now , It maybe wise to think about getting a new one or a later model used like a SC model. You can get some killer deal on them now.
    Dan
  • bigaudiofanatic
    edited July 2012
    mantis wrote: »
    Just to be clear
    Yes to all, and even in all channel stereo I am not getting audio in the rears.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • rooftop59
    rooftop59 Posts: 8,120
    edited July 2012
    Ok so I guess I would start with the obvious. Are the rear surrounds turned on in the setup menu? If yes, then do you have a global setup or can you change it based on the input or surround mode? I know that with my HK 745 I can customize each input completely differently, so I could have surrounds turned off for certain inputs but would still get test tones to go through.
    Other than that I am stumped...
    Game Room 5.1.4:
    Bedroom 2.1
  • bigaudiofanatic
    edited June 2013
    I actually found the problem just by messing around tonight. There is a button on the front for speaker selection as soon as I hit it BAM rears had audio.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • hertz9753
    hertz9753 Posts: 310
    edited June 2013
    That was a big bump. :biggrin:
    If your running 5.1 your back speakers should be connected to surround and not rear. I could be wrong, maybe...
    AVR-Onkyo TX-NR808
    Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
    Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
    Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
    Sub-Velodyne SPL-1000R
