Need help with buzzing noise
  • inson71
    inson71 Posts: 90
    edited July 2012
    Hey fellas, I bought a $39 Monster power strip with coax protection. I'll be darned if the thing eliminated 95 percent of the noise. The noise can now only be heard if my ear is within a foot of the tweeter. Seems like a bit of a band aid fix, but I will take it.
    Cooljazz- I will unhook above power strip tomorrow and lift that ground. If that eliminates the problem, what is the next step? A better grounding point? Better wire? It has to be grounded, right?
    Thanks again for everyone that helped!!! James
    Onkyo Pr-sc 5509
    Parasound 2250/Parasound 5125
    SVS PB 12 Plus
    Denon DBP-2012 Bluray
    Polk RTI 8, CSI 3, 4 FXI 3
    Sony 55" LCD
    tonyb Posts: 33,068
    edited July 2012
    So I guess you were a good candidate for a power conditioner. Still, you have a grounding issue somewhere in the chain. Maybe pickup a few more cheater plugs and play around with different pieces or combinations. A cheater plug in essense just lifts that ground to whatever it is added on to.
    Glad your close to getting it fixed altogether anyway, rock on.
  • inson71
    inson71 Posts: 90
    edited July 2012
    tonyb wrote: »
    I can see the light at the end of the tunnel! Thanks again!
    Onkyo Pr-sc 5509
    SVS PB 12 Plus
    Sony 55" LCD
