Any HVAC guys in the house ?
  • jimsvm
    jimsvm Posts: 307
    edited July 2012
    Honeywell vision pro 8000 is the best of Honeywell residential
    Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
  • Systems
    Systems Posts: 14,872
    edited July 2012
    If you have to replace the start cap, I would recommend the Clarity Cap ESA at least.
    And maybe upgrade the power supply (VH style for the wiring?).:wink:
    Maybe put the unit on spikes if you can?
    Mine seems to be colder after the "upgrades"!:cheesygrin:
    Hope this helps Tony!:lol:
    Testing
    Testing
    Testing
  • [Deleted User]
    [Deleted User] Posts: 1,223
    edited July 2012
    pepster wrote: »
    Nicely done ! Got a chuckle out of that one. Was the midrange bloom very noticeable ? :cool:
  • [Deleted User]
    edited July 2012
    disneyjoe7 wrote: »
    Gee someone agreed with me on Cap Woo Hoo...
    rpf65 hope you rock out some also. :smile:
    Ding, ding, ding, ding ......... we have a winner. It was the motor run cap on the blower.
    Parts were $9.00 + shipping. Thanks for the help. Cheers. :cool:
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2012
    nap wrote: »
    Glad it was pretty cheap and was pretty easy to fix it.
    My Bill is $223.43 Trip is $382.13 total $605.56...... Hmmm.... Now wait.... When I blow up a speaker or crossover, I never got a bill from Polk. So I feel we're good. :cool: :wink:
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Systems
    edited July 2012
    I would still try to "spike" your unit Tony, you would be shocked at how much colder it gets!:lol:
    Testing
    Testing
    Testing
  • mantis
    mantis Posts: 17,561
    edited July 2012
    I had a company come out and check out my system. They want to replace the outside unit , coil and all lines. Then replace the current thermostat with a much better unit.
    Job's gonna cost me 3500.00 , I think it's very worth the money especially when it gets to 100+ outside and my current system can't get the house under 83 F . it takes all night and into the morning non stop running to get the house to 74 F and at this time it's 70 F outside. It's been acting up the last few years and honestly I think its never ran properly so I'm excited about the upgrade.
    They are Installing a full Rheem system.
    Dan
  • disneyjoe7
    edited July 2012
    Dan, How old is that AC system of yours?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • mantis
    edited July 2012
    disneyjoe7 wrote: »
    it's only 8 going on 9 years old. It is as old as my house is. We had the house built in 2003. It's been acting up for years and I'm finally sick and tired of guys coming to my house and telling me different things why it doesn't work right. So I decided to get it all out and get a better unit in the Rheem system which is rated 1 and 2 depending on where you read about it.
    I'm not happy at all about this as I change the filter 4 to 6 times or more a year, had the coil cleaned , had the pressure checked which is what no one can get right or figure out why it doesn't have the right readings. And my cool to heat exchange difference is only 10 deg. It is suppose to be 20 deg difference or more.
    Dan
  • disneyjoe7
    edited July 2012
    Dan, I understand. 10 deg is really bad, does your neighbors have the same problem? I've seen houses that are not built correct, and the owners have problems later. If I had to guess your AC system is too big, or the fan is too fast.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
