Niles Integrated amp vs power amps
colin808
colin808 Posts: 47
edited July 2012 in Electronics
I have a Pioneer Elite VSX56TXi and a pair of Polk 11t monitors. I also have a Niles 275 integrated amplifier. I was wondering if I should pick up a Niles 2125 integrated amp or a Onkyo M282 power amp. What makes a difference between integrated and power? From what I understand, integrated I dont need a pre amp and with a power amp I need a pre amp.
Also, will the Niles 2125 or the M282 work with the Pioneer receiver? The receiver has pre outs for all channels.
If I do get the 2125 or M282, I will use that for the Polk 11t and use the 275 for the rears when I get them.
New to home audio so any advice is appreciated.
Post edited by colin808 on
  • colin808
    colin808 Posts: 47
    edited July 2012
    There is a used Niles 2125 for $200 but maybe I can talk price down a little. The M282 is $200 new.
  • deronb1
    deronb1 Posts: 5,021
    edited July 2012
    If you are going to use the 11Ts for HT as well as 2 ch, then yes get the power amp and hook it up to your elite. The Niles integrated should power the speakers just fine if they are only for music.
  • colin808
    colin808 Posts: 47
    edited July 2012
    catsfan1 wrote: »
    it will be good only for music? not movies or anything else? I think the niles might actually be a power amp since it doesnt have volume knob.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited July 2012
    For what ever reason (and this going off thread a bit ) I thought Niles always made the periferial gear .Volume controls ,speaker selectors ,some ceiling speakers and other switchers.So how are their ampifiers,pre/amps and any other main units compared to the usual fare we talk about.
  • arny
    arny Posts: 37
    edited July 2012
    colin808 wrote: »
    From the front and the back it looks like a power amp:
    edited July 2012
    Niles isn't exactly known for their amps in a HT application. They more so serve distribution purposes such as whole house/zone amps for back ground music. Dedicated 2 channel or HT, plenty of other better options out there.
  • colin808
    colin808 Posts: 47
    edited July 2012
    the Niles is 125 x 2 @ 8 ohms for $200 used. Ive tried looking around but dont know much about amps or good amps espcecially relatively cheap even used. Any ideas?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited July 2012
    I would avoid the Niles amps. They're not much better than what you can find in better AVRs or pro amps. if you had a really low end AVR it may be worth it, but given what your have now I'd say wait up until you can pull maybe 500 bucks together and you can get a lot of amp for that price.
  • colin808
    colin808 Posts: 47
    edited July 2012
    @AsSiMiLaTeD
    how do you like the hk3490? I think I might get that down the road..
    i dont know too much but i saw that the Niles has high current and from what ive seen thats good. Alot of people do say that Niles isnt advised though.
  • zingo
    zingo Posts: 11,258
    edited July 2012
    PM sent
  • AsSiMiLaTeD
    edited July 2012
    I have a 3490 sitting right here in the office, and it's superb.
  • colin808
    colin808 Posts: 47
    edited July 2012
    Any thoughts on the Yamaha M-80?
