New SoundBar 6000 turns off automatically
Tridogdude
Tridogdude Posts: 2
edited August 2013 in Troubleshooting
Recently returned the 4000IHT since the sound was not very good for the room we have it in. Saturday we upgraded to the 6000 and it seems much better.
The problem we are having is that the sound bar automatically shuts off after 5-10 minutes. Not sure what is causing this and I don't see anything in the manual troubleshooting guide. It did it only several times the first day we used it but today it is doing it constantly.
The other issue is that when the TV is turned off and then later turned on, the sound is so low that we have to turn it up with the Polk remote even though we programmed our Direct TV remote to work with the sound bar. Is there anything we can do to alleviate this? Having to use two remotes is a little bit of an annoyance.
Post edited by Tridogdude on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited February 2012
    Hello TDD,
    Welcome to Polk's forum. From your description it sounds as though the SB is going into standby, which is usually caused by a too low level incoming signal. Try going into the TV's setup menu and changing the audio output from "variable" to "fixed" and turning off the built in TV speakers. As to the second problem it not a good idea to use the Direct TV remote to program the Polk. The reason is that the Direct remote is going to "speak" too many control languages, at the same time, for the Polk to learn. You have to use a single language remote, such as the TV's remote (assuming it is an IR remote as opposed to an RF remote), once you've done that the Direct remote will control it. But, first you need to wipe the Polk memory. To do that put the unit in standby, the LED will be amber. Then touch the "learn" button for a count of two, the LED will blink twice then go steady amber. Once this is done you can turn the SB on and then use the TV remote and go through the programming operation and the Polk should work fine.
    Regards, Ken
  • Serendipity
    Serendipity Posts: 6,975
    Which model TV do you have? Some TV's need to have their internal speakers set to "OFF" before they can be set to fixed or variable audio output. If not, you may need to keep the TV volume at a respectable level or use the fixed setting.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Baudman
    Baudman Posts: 1
    edited July 2012
    I have this same issue when using an ipod in source 2 or 3. Is the SB defective? or how do i stop it from going into sleep mode? Id like to play more than 2 songs lol
  • [Deleted User]
    edited July 2012
    Hello,
    Welcome to Polk's forum. In all likelihood the SB is going into the auto off mode because the signal coming from the iPod is below the speaker's threshold. I am assuming you are going from the iPod's headphone output, correct? You would want to set the output level at the highest setting, but I'm sure it doesn't produce much of a signal (earbuds must use femtowatts for power).
    Regards, Ken
  • Teth
    Teth Posts: 1
    edited July 2012
    We have had our soundbar 6000 for 1.5 years. It has always worked fine. All of a sudden it turns off after 5-10 min when we are not touching any remotes and the volume is not changing. Is this possibly still a cable problem or do we likely have to send it somewhere for repair?
  • [Deleted User]
    edited July 2012
    Hello Teth,
    If you haven't made any changes to the device(s) that are feeding the signal to the SB then I would telephone Polk's CS department at 1-800-377-7655. I'm sure they can be of help.
    Best regards, Ken
  • epearson
    epearson Posts: 1
    edited August 2013
    I just purchased the soundbar 6000. I'm overall happy with the sound when playing movies and from my DVR, but playing pandora from my iPhone or playing music from an iPod, it will automatically go into standby mode. Its a bit frustrating, I've turned both devices to full volume, but that doesn't work. As you specified, it may be the output level is too low, but regardless the soundbar should still be aware that there is an audio signal coming in and not turn off. It seems to be a design flaw to me and a big one at that. I'm still debating if I'm going to return it.
  • dish1
    dish1 Posts: 1
    I have a Polk fs1 (I believe) 2nd gen model offered by dish Network. After a few minutes without input it powers of or enters standby rather. I understand this to be a power saving feature and I appreciate not having to power it on and off when I'm finished using it. However if I pause something for a breif time I hate having to wait for the sound to resume leading me to miss little bits of whatever I'm enjoying. Is there a way to extend the delay before going to sleep or even a way to disable it? Thanks for any help.
