tsi 100 searching for Receiver
waheeb
waheeb Posts: 1
hello all
im new here and im new also on this kinda stuff speakers
i want to buy a tsi100 or tsi200 polk audio speakers and im searching for the best
Receiver for these speakers I hope you can help me chose one
some one told me about the RX-V371 yamaha for polk audio speakers ..?
"Signal-to-Noise Ratio" when its higher is better ? because i saw some wiht 98 and some with 100
and by the way i dont have much money i want to spent 750$ on these
one more thing i have car Subwoofer dose it match with the home i think i can connect it its "kicker cvr 12"
and i also have samsung hometheater written on the box 800 watts Rms all and dont and cant get the spec its 5.1 hometheater
i really hope you can help me fast guys because i wanna buy it fast because i need to order it and will take like 3-7 days and i cant wait
and thanks any way guys
sorry for my english
Post edited by waheeb on
  • camp21178
    camp21178 Posts: 273
    edited June 2012
    Sorry that nobody answered. I have played my tsi100s with an old 1984 Harman Kardon PM650 and a new Denon surround receiver. They sounded way better with the HK to me. I have a Volodyne sub and they match very well.
    edited June 2012
    Welcome to Club Polk!
    Sorry we didn't pick up your post earlier!
    Firstly, "disregard' the statistics you list above, especially the Samsung ones if that's a Home Theater In a Box [HTIB]. All those numbers are Fluff!
    Where are you "located"??
    And are you setting up a Home Theater or just two channel. If Home Theater, move up to the Yamaha Aventage series (whichever one you can afford).
    Do you think you might "upgrade" your system? Because if you do. Save for a receiver with pre-outs (those are RCA outs on the back of the receiver that allow you to hook up a MORE powerful external power amplifier and NOT use the internal amps on the receiver).
    If that's not an issue for you. Look at the Yamaha RX 67X series. Or a Pioneer VSX 11XX series. Etc.
    Do you like the Yamaha sound? Have you heard it? If not, go out and listen to Onkyo, Pioneer, Yamaha, Harman Kardon, etc. in the 400-500 dollar range if you want a mid-range AVR. Most pieces under that price point...well, they're entry level and you can do "better"!
    TSI series sound pretty good with almost "any" of these receivers IMO, so that's a plus!
    Good Luck!
    cnh
