Power Supply Upgrade for Squeezebox Touch
audiocr381ve
audiocr381ve Posts: 2,588
edited February 2013 in Going Digital
Channel Islands is out of stock and the only other aftermarket power supply I see available is the one from Valab on eBay. Does anyone have any recommendations?
Post edited by audiocr381ve on
  • FTGV
    FTGV Posts: 3,650
    edited June 2012
    I know Scompracer and some others use this and seem to be pleased with build quality and performance.Apparently they can be a bit flaky to deal with though. http://www.welbornelabs.com/squeeze.htm
  • audiocr381ve
    edited June 2012
    FTGV wrote: »
    Thanks FTGV. Do you know if the kit is hard to assemble?
  • vcwatkins
    vcwatkins Posts: 1,992
    edited June 2012
    I got mine from Welborne after some folks here had experienced less-than-stellar customer service. My order was processed and shipped fairly quickly and communication was fine. The price of the Welborne was difficult for me to swallow (no way I could stomach the CI cost), but I'm glad I did it and would do it again. Would use Welborne again too. Dunno if anyone has ordered since then.
    Craig
  • FTGV
    FTGV Posts: 3,650
    edited June 2012
    Should be very simple for someone with decent soldering skills.If in doubt buy the assembled unit and save yourself some possible grief.
  • audiocr381ve
    edited June 2012
    Cool, thanks guys.
  • BlueFox
    BlueFox Posts: 15,250
    edited June 2012
    Will this work?
    http://www.audioadvisor.com/prodinfo.asp?number=PGP100
    I used CIAUDIO VCA-9 upgrade for my Wadia 171, and the improvement is not subtle. However, Music Direct no longer carries it, but while looking for it I found this, which appears to meet your need.
    http://www.musicdirect.com/p-4989-ciaudio-vdc-sb-squeezebox-high-current-power-supply.aspx
  • FTGV
    FTGV Posts: 3,650
    edited June 2012
    BlueFox wrote: »
    That looks to be for specific MF and Cambridge models only.
    SCompRacer Posts: 9,137
    edited June 2012
    The Welborne Lab's kit is easy to assemble. Hardest part of assembly would be the umbilical power cord; the small diameter connector that plugs into the Touch. IIRC you have to watch the height of the caps (keep them close to the board), as you slide the board into slots in the chassis.
    EDIT: I recall them being short the Techflex covering for the umbilical. They sent the kit and said they would mail out the Techflex, and they did a week later.
  • chandler9a
    chandler9a Posts: 885
    edited June 2012
    Shane, check out the Gon. I believe there is a Channel Island unit for sale there. I could be wrong.
  • zingo
    zingo Posts: 11,258
    I'm pulling this thread back to life :)
    Has anyone tried a power supply like this from Elpac? http://www.ebay.com/itm/ELPAC-POWER-SYSTEMS-SOLV-30-5-N-OVP-5V-6A-DC-POWER-SUPPLY-/290821860664?pt=LH_DefaultDomain_0&hash=item43b6556d38
    I know the current rating is over-kill, but it's 5V DC, and should work when mounted in a case? It's not fancy, but it should provide much better power than the supplied wallwart.
    Please correct me if I'm wrong...
