Polk Audio 2BTL Crossover Modification Thread
VR3
Coming to a forum near you!
Clarity Cap ESA on the tweeter network, PX on the midbass/SDA
Upgraded SDA cable featuring dual wound 13 awg cable - should be nice!
Post edited by VR3 on
I have done a couple of these. Like to see how yours turns out.
Original Boards or are you using Gimpgods? -
These will be using the original boards -
I have performed the TL mod on a set of CRS+ which is similar- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Not just similar, they are nearly identical.
Nice job on the CRS ones above. I would personally take it easy with the hot glue myself though. Just a dab will do ya.
They look good though. -
The two Solens on top have their leads twisted together, but not attached to anything else. How come :question:"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
They connect to the 40uf spot on the other side of the board.. I might have a picture- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I always put a little more hot glue than normal as I am shipping these back to people...
Just about every crossover I receive parts are dislodged when I open them up... I cant have that happen when they receive them back- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Good Point about the hot glue.
Nice. I havent done a set of his boards yet. Mostly cause I am cheap but haven't needed boards recently.
You know I wish I had gone Clarity with CRS+'s but I only have about 200 hours on them now. We are expanding the building at work and I will have a nice big office so I'm waiting till its all done to give them a new home. I won't be going real big with the gear my SL2000 will more then likely be the pre I will use and I'm on the hunt for a 555/545 amp to power them with. I even have some room treatments to go in the office as well. Can't wait!!
Gimpod was working on a set of boards for the 1.2tls to hold Clarity caps as I plan to go out board x overs in the future.. -
I love the end result with Clarity Cap man... they are literally awesome- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I still am but got side tracked for a bit sorry. I have to put together a list of questions that I need answers to before I can proceed, I'll try and get that to you next week sometime.Gimpod was working on a set of boards for the 1.2tls to hold Clarity caps as I plan to go out board x overs in the future..“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Larry,
I (and I'm sure many others) recommend going all ESA (or better if you can swing the $$$$$). You will absolutely love the audio (along with the the Duelund Cast resistors) the Clarity Caps produce.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
No need to hurry as I have time and it's not like I will be starting it anytime soon.. -
Mock up, teasing Kerry- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Ah the things you can do while you wait on laundry to dry...
Jantzen inductors!
Almost there
Connectors, SDA inductor connection, some soldering.. bada bing... bada boom- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Everything soldered and SDA inductor connected! :-D- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
New "SDA" cable
Jay
I have grown a liking to Supra wire..
This is Supra RONDO dual 13 awg run
All done - just waiting on Kerry to send me the rest of the internal wiring that I didnt notice was not in the box @_@ :-P- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
New camera test- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
