Polk Audio 2BTL Crossover Modification Thread
VR3
VR3 Posts: 29,496
edited September 2012 in DIY, Mods & Tweaks
Coming to a forum near you!
Clarity Cap ESA on the tweeter network, PX on the midbass/SDA
Upgraded SDA cable featuring dual wound 13 awg cable - should be nice! :)
Post edited by VR3 on
  • Joe08867
    Joe08867 Posts: 3,919
    edited June 2012
    I have done a couple of these. Like to see how yours turns out.
    Original Boards or are you using Gimpgods?
    VR3 Posts: 29,496
    edited June 2012
    These will be using the original boards -
    I have performed the TL mod on a set of CRS+ which is similar
  • Joe08867
    edited June 2012
    Not just similar, they are nearly identical.
    Nice job on the CRS ones above. I would personally take it easy with the hot glue myself though. Just a dab will do ya.
    They look good though.
  • drumminman
    drumminman Posts: 3,396
    edited June 2012
    The two Solens on top have their leads twisted together, but not attached to anything else. How come :question:
    VR3 Posts: 29,496
    edited June 2012
    They connect to the 40uf spot on the other side of the board.. I might have a picture
    VR3 Posts: 29,496
    edited June 2012
    I always put a little more hot glue than normal as I am shipping these back to people...
    Just about every crossover I receive parts are dislodged when I open them up... I cant have that happen when they receive them back
  • Joe08867
    edited June 2012
    Good Point about the hot glue.
    VR3 Posts: 29,496
    edited June 2012
    These just got more awesome!
    GIMPOD boards coming this way! SUHWEET!
    www.GIMPOD.com
  • Joe08867
    edited June 2012
    Nice. I havent done a set of his boards yet. Mostly cause I am cheap but haven't needed boards recently.
    Toolfan66 Posts: 18,125
    edited June 2012
    You know I wish I had gone Clarity with CRS+'s but I only have about 200 hours on them now. We are expanding the building at work and I will have a nice big office so I'm waiting till its all done to give them a new home. I won't be going real big with the gear my SL2000 will more then likely be the pre I will use and I'm on the hunt for a 555/545 amp to power them with. I even have some room treatments to go in the office as well. Can't wait!!
    Gimpod was working on a set of boards for the 1.2tls to hold Clarity caps as I plan to go out board x overs in the future..
    VR3 Posts: 29,496
    edited June 2012
    I love the end result with Clarity Cap man... they are literally awesome
  • gimpod
    gimpod Posts: 1,793
    edited June 2012
    Toolfan66 wrote: »
    I still am but got side tracked for a bit sorry. I have to put together a list of questions that I need answers to before I can proceed, I'll try and get that to you next week sometime.
  • headrott
    headrott Posts: 5,496
    edited June 2012
    Toolfan66 wrote: »
    Larry,
    I (and I'm sure many others) recommend going all ESA (or better if you can swing the $$$$$). You will absolutely love the audio (along with the the Duelund Cast resistors) the Clarity Caps produce.
    edited June 2012
    gimpod wrote: »
    No need to hurry as I have time and it's not like I will be starting it anytime soon..
    VR3 Posts: 29,496
    edited August 2012
    Mock up, teasing Kerry
    VR3 Posts: 29,496
    edited August 2012
    Ah the things you can do while you wait on laundry to dry...
    Jantzen inductors! :)
    VR3 Posts: 29,496
    edited August 2012
    Almost there
    Connectors, SDA inductor connection, some soldering.. bada bing... bada boom
    VR3 Posts: 29,496
    edited August 2012
    Everything soldered and SDA inductor connected! :-D
    VR3 Posts: 29,496
    edited August 2012
    New "SDA" cable :)
  • agfrost
    agfrost Posts: 2,472
    edited August 2012
    VR3 wrote: »
    New "SDA" cable :)
    What cable did you use?
    Jay
    VR3 Posts: 29,496
    edited August 2012
    I have grown a liking to Supra wire..
    This is Supra RONDO dual 13 awg run
    VR3 Posts: 29,496
    edited August 2012
    All done - just waiting on Kerry to send me the rest of the internal wiring that I didnt notice was not in the box @_@ :-P
    VR3 Posts: 29,496
    New camera test
