All the Polk SDA upgrades located in one place!
VR3
I figured this would help some folks find all the tweaks!
If I missed any, please let me know! Please let me know if there is a better link than the one I used as well!
Thanks!
http://vr3mods.com/LCSDAUpgrade.php
Thanks!
Link was added on how to remove Hot glue 06/14/12- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Congrats on becoming a STICKY!:cheesygrin:
And thanks for the link... This is a brilliant idea that was long overdue imho.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Yes a great Idea!!
Thanks!! -
Updated 6/15- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Posted this in the other thread but I didn't want it to get glossed over. Some info from Matthew Polk regarding the Bass Brace:
Tony –
The “Bass-Brace” was introduced as a recommended modification for the SRS 1.2 and was available free for the asking. The kit was composed of nothing more than a piece of all-thread, ?” I think, with a t-nut for the back of the cabinet and an selection of wall anchors. All late production SRS models came with the t-nut already installed in the back of the cabinet plugged with a bolt to seal the hole. (Note: when the all-thread is screwed into the cabinet it will often wind Dacron around it like cotton candy jamming in place and requiring removal of a driver to free-up.)
The “Bass-Brace” did make a noticeable difference in bass performance. Slam and speed were noticeably improved. If you anchored to a masonry wall the difference was really quite dramatic, more than you’d get from improving your speaker cables and even better than spikes.
However, the real reason for the Bass-Brace was not initially to improve performance. Around that time new industry safety guidelines were issued for loudspeakers which included a “tip test”. The tip test specified that with the speaker placed on an inclined plane at 10 deg. (as best I recall) it would not tip over in any orientation. Needless to say, the SRS products did not pass. That was a real problem and with an inventory of product already in the warehouse we needed a solution. The solution was the Bass-Brace which when installed prevents the speaker from tipping over. But, when trying it out we realized it also made a significant performance improvement. So, it became both a performance modification and a safety feature. However, it was very difficult to install and I doubt many SRS owners ever enjoyed the benefits. Over Amy’s objections I did install mine and anchored them to an 18” thick brick and masonry wall. It was very impressive.
Hope that helps
-msp
Cheers. :cool: -
Thanks Nap
Updated page for information on common ground amplifiers and Dreadnou- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks!
http://vr3mods.com/LCSDAUpgrade.html
I have a SDA II owners manual if you're interested in adding it to your link?Monitor 7C's With Tubes -
Sorry I missed this earlier, email has been sent.Monitor 7C's With Tubes -
Added SDA 2 manual!
Thanks!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
When I bought my SDA 2B Studios back in 1988, the salesman gave me a pamphlet that detailed how the salespeople were supposed to demonstrate the SDA's. A lot of it was positioning of the speakers and is covered under the owner's manual. It also included 3 pages of songs to demonstrate the abilities of the SDA's. The guy said they normally didn't give out this pamphlet. I'll send it to you tonight/tomorrow and you can look it over and see if you want to post it under other information.
Fixed some broken links, all links now point to an external source
Added sales brochure/general setup information- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Added link to 40 page pdf to help ID vintage Polk models- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Updated 7/20 to include crossover design and progressive point source info
You know I see all these SDA ads and reviews selling on Ebay for like $10
I wish we had a place to put every old ad and review in one place.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
find them and I will add it!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Updated 8/29/12
Refined the organization, added a few more links, updated some info
Thanks- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Added Link on how to convert a SDA1 to a SDA 1A- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Trey, can you add the "bass brace" mod that Raife did for his 1.2TL's and/or SRS's please? I didn't see it on your page, and others may like to read up on how Raife did it. Thanks Trey.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I actually searched for this when I first did the page... no such luck finding the link...
Do you by chance have it?
Trey, look at post 32 here: http://www.polkaudio.com/forums/showthread.php?123136-SDA-Driver-Seals-Original-Foam-vs.-Mortite-vs.-Armaflex-Foam&p=1640225&viewfull=1#post1640225"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
ADDED and done :-D
ADDED and done :-D
No problem! That site is a great reference I am glad to help get built so when my SDA time comes, bam no work to find all this crap, just head to your site and start printing :biggrin:"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Yup yup....
I try to keep an eye on new stuff and obviously as I do mods I learn more and More, like the 1A information...
Fun stuff either way
Wow, you guys are too quick! Anyway, thanks Ender and VR3.
Its what happens when you have insomnia, you stare at the computer most of the night :biggrin:....
That and I love you guys enough to google search and track it down
Jimmy Johns fast... FREAKY- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Added the SDA Handbook by Ray!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
