Re-reverse phase on pioneer MCACC?
bansheesho
bansheesho Posts: 227
When I first got the q600 center and ran the MCACC calibration it told me to reverse phase on the center channel, so I did even though that meant hooking the black to red and red to black. I ran it since then to setup a pair of speakers to sell and then reran it with the KEFs back in place and it was fine with the way they were hooked up.
Well I ran it again tonight to erase some bad eq trials and it told me to reverse phase back to normal red to red/black to black. I tried it a couple of times to make sure it wasn't a fluke..
So my question is why would this change if I haven't changed anything in the system?
Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
Post edited by bansheesho on
  • mantis
    mantis Posts: 17,365
    edited June 2012
    I've never seen that ever. You might have something wrong with that center , you might have bad reflection problems or very crappy placement. Something is very wrong if this is what your getting. usually when it says to reverse phase mean you wired your speaker wrong.
    Dan
  • Syndil
    Syndil Posts: 1,582
    edited June 2012
    Did it also change the timing (delay in ms) of any of your speakers when you reran it?
  • bansheesho
    edited June 2012
    That I don't know I didn't really check, but I wouldn't think by much.. I usually hit the run button and then leave so I don't affect anything. I haven't changed anything.
  • Syndil
    Syndil Posts: 1,582
    edited June 2012
    I was thinking that the speaker may be placed in a position where it is right on the edge from being in or out of phase, which could confuse the MCACC. If the delay changed with the phasing, then the combination of the two could result in the same sound coming from the speaker that you had before the change.
    If a speaker is out of phase it should be fairly obvious, IF you know how to listen for it. If you have a DVD with the THX Optimizer on it there is a test for phasing on there. However if your speaker is right at the edge of being in/out of phase (90 or 270 degrees out of phase), then the test should sound about the same when it is playing in or out of phase.
