New woofer for PSW-300?
audio_alan
Hey everyone, my friend just bought a set of older Polk speakers that included a PSW-300. The plate amp seems fine, but the woofer is shot. I looked at Polk's product page for that sub, but don't know if it's a 8 ohm driver or not.
http://www.polkaudio.com/homeaudio/products/recent/psw300/
Any suggestions on a cheap replacement? He told me that he doesn't want to sink more to $30-$40 into it though. If it's more, he'll probably just look for a different sub...
I was thinking of suggesting one of these to him:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-315
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-486
Thanks.
Thanks.
Post edited by audio_alan on
IMHO, it's not worth repairing a PSW300... It's a bandpass design which limits bass output. I have one and it distorts easily at moderate volumes. What's wrong with the driver? usually, the spider separates from the cone due to a poor adhesive. You can use a superglue to reattach the spider if this is the case.
Jon - Yeah, the spider came unglued (sounds like a common thing with that model). But even holding it together, the cone still makes a rubbing sound. I'm thinking the voice coil might be warped or something as well, basically making the woofer a lost cause at this point.
My friend thought it might be fun to try getting a cheap woofer just to see if he could get it functional and maybe flip it for a little extra money if he doesn't like it. -
Love my PSW-300. The bandpass design is great for a subwoofer that is intended to be used as a subwoofer and not a midbass driver--maybe you're sending too much midbass to yours. My mains get down to around 35Hz and I have the crossover on my pre set to 40, so my PSW-300 doesn't get tasked with any midbass work. I can shake the foundations without distortion.
IMHO the PSW-300 is one of the best sub designs Polk has made--if you want a true subwoofer.
That said if I was going to replace the woofer, I would only consider replacing it with the woofer it was designed and tuned to work with.
Monster AVL-300, HTS-2500 MKII -
I don't know how much of a difference there is between the 300 and 303 but: http://reconingspeakers.com/products-page/woofers/polk-psw303-8-woofer/
You can always contact them or Polk to see what they say.
A random $40 woofer is a bad idea."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Face - Yeah, I kind of wonder how well a random woofer will work as well, but I think he wants to try it. Contacting Polk is a good idea though. They might have a drop-in replacement that might work better than any xyz brand...
I can tell by looking at the pics (assuming that is the pic of the actual woofer) that the 303 woofer is not similar to the 300 woofer.
Edit:
Heck, just noticed the 303 woofer is 8". The 300 is a 10". So yeah, definitely not similar.
Syndil - Yeah, definitely not a match. It was a good idea though.
I haven't heard back yet from my friend on what he wants to do. I agree that a random woofer is a hit or miss proposition. -
If your going to try a random SUBWOOFER make sure it is a SUBWOOFER and not just a woofer. A regular woofer won't go low enough and really negate the idea.
Also make sure it is made for a small enclosure. The box this is in is about 1cu ft so the sub needs to work in that small a space.
I wouldn't worry to much about power handling but I would get above the 80watt mark of the speakers you have shown. That sub has a dynamic power of 300 watts. About 150 nominal. -
My friend just sent me a message saying he bought a woofer. I'm not sure which model yet. I'll let you guys know how it turns out...
audio_alan wrote: »Jon - Yeah, the spider came unglued (sounds like a common thing with that model). But even holding it together, the cone still makes a rubbing sound. I'm thinking the voice coil might be warped or something as well, basically making the woofer a lost cause at this point.
