SDA question
dromunds
dromunds Posts: 10,140
edited June 2012 in Vintage Speakers
Were all original SDA 1 speakers considered "signature" speakers? How do the original SDA 1's compare to the SDA 2b?
Post edited by dromunds on
    F1nut Posts: 52,002
    edited June 2012
    No.
    The 2B's are the better speaker.
  • Schurkey
    Schurkey Posts: 2,122
    edited June 2012
    The original SDA 1 had a vented cabinet. The 1A eliminated the vent.
    Polk had an "update kit" to convert the 1 to a 1A. The vents were plugged with wood dowels, then--I think--the dowels were covered with a brass plaque having Polk's signature. I did a quick look at the 1-to-1A Signature instructions, but could not find a reference to the signature plaque. Maybe I'm hallucinating about the brass plaque.
    http://www.polkaudio.com/forums/attachment.php?attachmentid=31009&d=1201824729
  • falconcry72
    falconcry72 Posts: 3,580
    edited June 2012
    Schurkey wrote: »
    ...the dowels were covered with a brass plaque having Polk's signature. I did a quick look at the 1-to-1A Signature instructions, but could not find a reference to the signature plaque.
    And don't confuse these "signatures" with the "Signature Reference Series" SDA's.
    pitdogg2 Posts: 27,319
    edited June 2012
    Schurkey wrote: »
    not hallucinating at all the plaque only came on the factory models though.
  • Schurkey
    edited June 2012
    YES!
    Thank you for the sanity reinforcement.
