8 ohm or 4 ohm
Graymane
Graymane Posts: 92
Just got a new pair of speakers that are 6 ohm and the conections on my Jolida are for 8 ohm or 4 ohm. Which would be recommended for 6 ohm speakers? Thanks
Post edited by Graymane on
  • decal
    decal Posts: 3,205
    edited June 2012
    Which ones sound best to you?
  • Graymane
    Graymane Posts: 92
    edited June 2012
    Haven't tried them either way yet. Don't want to damage the speakers or the amp. If it's purely a sound issue I'll try 4 ohm's first.
    mhardy6647 Posts: 35,179
    edited June 2012
    decal wrote: »
    This is the right answer. Either tap is equally appropriate; pick the one that sounds better to you.
    Also, always bear in mind that the "nominal" impedance of a speaker system is just that - nominal. The actual impedance will vary as a function of frequency, with a peak at the system's resonance, a smooth flat region above it (the "nominal" impedance is taken from that flat region - typically in the range of 100 to 200 Hz), and who-knows-what above that!
  • Graymane
    Graymane Posts: 92
    edited June 2012
    Thanks for the replies and the help. will be hooking them up tomorrow night after work Time for a growler of micro brew and some listening.
