Bass Shaker amplification
ROHfan
Just a quick FYI about Bass Shakers. Don't be fooled into thinking you need a 50 or 100 watt amp for them.
I just hooked up a spare 2x15W Pyle Pro PCA1 to my shakers and it is more than adequate to power them. Volume is only up half way and it mixes perfectly with my powered sub. Coming in at only $25 there's no need to spend much more for adequate power.
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
What frequency are you sending to the shakers? I am thinking about getting some but was thumbing about sending only 15hz to around 35hz that way they only go off on the really low stuff.Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Legacy Audio Focus SE
Legacy Audio Silverscreen HD center
Polk F/X500i Rears
Parasound HCA-3500
Sunfire Grand Cinema
Behringer iNUKE NU6000DSP
Pair of CraigSUB SS-18.1 -
I'm crossing over at 60Hz and it seems to be perfect. I haven't really played around with the lpf because they're integrated pretty well now and I'm happy with it.TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
What kinda' shakers? 'Cause I'm sure that kinda' wattage is fine for something like the Auras, but I wouldn't think so for something like a Buttkicker.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
kuntasensei wrote: »What kinda' shakers? 'Cause I'm sure that kinda' wattage is fine for something like the Auras, but I wouldn't think so for something like a Buttkicker.
You are correct, Aura Pros. I don't have experience with buttkickers. Why do you think it wouldn't work for the buttkickers?TV: 65" Samsung QLED 4K
Oh, I'm sure it would work to an extent... but Aura Pros are small... whereas a Buttkicker LFE is a 3" steel piston in an enclosure.Equipment list:
Emotiva XPA-3 amp
Buttkicker sells a 1200W amp that can drive up to 4. I have been looking at this to put into my new two step risers because I'll have 9 seats.
I don't think that you could get away with 15W. My Home Theater:
Mains: polkaudio RTi150
Center: polkaudio CS350LS (modified)
Side: polkaudio 65-RT
Back: polkaudio RC85i Rear
Sub: SVS SB13-Plus
Receiver: Denon 4311ci
Sony VPL-VW60 on a 92" Draper Premier screen
Sony 52" XBR2
