Help With Banana Plugs
hith
hith Posts: 4
From what i can gather, I am having the same problem as the op in this thread
http://www.polkaudio.com/forums/showthread.php?109441-My-banana-plugs-won-t-fit-correctly-into-my-speakers&highlight=banana+plugs+won%27t+fit+correctly+speakers
I started a new thread in hopes to get my problem resolved. The banana plugs (GLS Locking Banana plugs gen 4) will not go all the way into the binding post. Pic below. Problem is on both CS2 center speaker and monitor 60 series II floor standing speakers. And no, they are not in the locked position when inserting. Please help. Thank you.
  • Face
    Face Posts: 14,340
    edited May 2012
    Try a little DeoxIT, it may allow you to insert them in all the way.
    EndersShadow Posts: 17,765
    edited May 2012
    I have the same problem with those plugs and my Lsi 15s. I just insert it as far as I can and leave it alone lol.
  • grimmace19
    grimmace19 Posts: 1,429
    edited May 2012
    Whatever you do, don't force them in until your binding posts break... :wink:
    txcoastal1 Posts: 13,520
    edited May 2012
    cbow8 wrote: »
    Very good point. Are you sppeaking from experience lolQUOTE]
    ask PFB...
  • teekay0007
    teekay0007 Posts: 2,288
    edited May 2012
    cbow8 wrote: »
    Im guessing pfb is a another member? Im j/k anyway. That is honestly good advice not to get carried away with them post. Not alot of metal there after they drill wire holes in them.
    pfb is Polkfarmboy, a skinny-jeans-wearin', take-no-crap-from-slow-payin' Ebay'ers kind of guy! :lol:
  • hith
    hith Posts: 4
    edited May 2012
    Thanks for all the replys everyone. They do stay in when locked but its annoying. I am goign to find some cable boots that will fit and see about replacing the stock binding posts in the future.
    edited May 2012
    hith wrote: »
    Honestly not worth switching the binding posts man. I would just if anything contact GLS and see if they can send you out another one since its probably a issue with their plug being a bit off overall.
    I personally just left it alone in mine and forgot about it :wink:
    edited May 2012
    Also if you replace the factory binding post you void the warranty on the speakers should something go wrong. Once again why its not worth it IMHO.
  • hith
    hith Posts: 4
    edited May 2012
    No, i will not be replacing my plugs any time soon. GLS says they just dont fit my posts. no explanation yet. Do the polk series have odd or cheap post sets? trying to figure out what to do to remedy the situation.
  • dcmartinpc
    dcmartinpc Posts: 844
    edited May 2012
    hith wrote: »
    That is weird. I run all GLS locking bananas and I have never had a problem getting them into the posts on any of my polk speakers. Have you tried give the tips a little squeeze with a pair of needle nose pliers to make sure they are completely compressed? thats the only thing I can think of. GLS has served me well. I just ordered another 48 of them because I like them so much!
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
  • hith
    hith Posts: 4
    edited June 2012
    dcmartinpc wrote: »
    Don
    I did not at first because i'm in the process of moving. i will have to try that next time i have everything hooked up. Right now everything is boxed up.
