If I switched to rti12's, would I still need my sub?
edited May 2012 in Speakers
Right now I have (this is a 5.1 system) 2 rti10's for my fronts and a polk psw450 subwoofer. I switched to rti12 fronts, would I still need that psw450? Or would the 12's be capable of producing similar bass quality? I understand it won't be exact, but is it comparable?
Post edited by mva5580 on
Welcome!
    edited May 2012
    You'll still want a sub, especially for movies. They'll produce a little more bass than your Rti10's but not a HUGE difference.
    edited May 2012
    I would not run a sub with either one of those speaker choices. I like big full range speakers and a sub isn't always the best choice when going for a coherent sound. I know most on here will disagree but I don't care. Too many people get a powered sub and do not know how to balance it into a system thereby making the low octaves sound too fake for me.
    edited May 2012
    I respectfully disagree on not needing a sub. I don't think the Rti12's have a ton of usable bass under about 45-50hz, and my sub plays to 18hz. If I didn't have it the bottom end would be missing and home theater experience would be very underwhelming. For music I could live without the sub but HT is a different story.
    edited May 2012
    Quick, simple answer....yes!
    edited May 2012
    rebuy wrote: »
    C'mon, he's talking 5.1 HT... you like 5.0 better?? Clearly, you're referring to music.
    However, OP, want and need are two different things... Could you enjoy a movie without a sub? Yes. Do you want to??
    edited May 2012
    Definate YES on needing the sub for HT. I would not run my Rti12's without the sub. Tried it and it aint no good.....
    Parasound HCA-2003A & 2205A
    Front: Rti12's
    Center: Csi A6
    Side surrounds: Polk Rti A1's
    Atmos: Mirage Nanosats
    APC H15
    Power cords by Pepster, Morrow MA4 IC's, AQ Midnight, AQ Chocolate HDMI's[/SIZE]
    The rest is TBD.
    edited May 2012
    Also a yes. I run equivalent speakers; RTiA9's and while they do put out some impressive bass, they don't come close to replacing my Empire!
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
    edited May 2012
    yup.....try it.....turn it off n try it......yup......you make the call....EDIT
    LET YOUR EARS DECIDE
    edited May 2012
    Upgrade and keep the sub.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    edited May 2012
    Well, lets keep in mind the OP's sub, the psw450. For movies you may want to keep the sub in the mix, for music though, I dunno man try it both ways and decide for yourself. The posters that say keep it, have way better subs than the 450. Let your own ears decide it's fate.
    edited May 2012
    I would mostly agree that you probably need to still run a sub for HT for RTi-12s. I used to own a pair and actually ran a pair of DSW-PRO 600s with them for HT. There are always exceptions to the rule however. I tried bi-amping the RTi-12s for a bit sending 400 wpc to each RTi-12. I can tell you in this configuration there were many times were I turned off my subs and I never even noticed they were off, even in HT appliciations. I can tell you for a fact that given enough good clean power, RTi-12s can put out some seriously hard hitting and low bass.
    edited May 2012
    tonyb wrote: »
    Translation: Upgrade your fronts AND your sub:cheesygrin:
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
    edited May 2012
    mystik610 wrote: »
    Nah...your fronts are just fine, but once you upgrade the sub (better yet 2 subs) it's like magic happened to your system for both HT & 2 channel.
    edited May 2012
    tonyb wrote: »
    Keep those 12's and look for another high quality sub and go with two subs. Then equalize everything( I recommend a antimode or velodyne sub equalizer if you can) . Sit back once you have two subs and change the front settings from large to small and back and let your ears make the choice. I did this and all I can say is it made a huge differance running the fronts at small and letting the subs handle everything 80hz and below. That being said, like Tony said it make a differance considering the sub(s). But those 12's are great fronts when powered correctly. I know this requires more upgrades but that is how it goes.......Just my 2 cents from my experiences.
    HT System
    Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
    edited May 2012
    ^^^ I don't think he has 12s, but rather 10s, which are still pretty cool, IMHO... :cool:
    edited May 2012
    rebuy wrote: »
    Everyone everywhere in every system needs a sub if they want to recreate the playback material. Balancing it into a system isn't the question here.
    Dan
    edited May 2012
    the rti12s have potential to put out good bass, then unlikely you will get there because u need to pump up the vol pretty high. I drive mine full range, but still send addition -60hz to the sub for music. For HT, you will NEED a sub regardless, otherwise u will miss the .1 channel.
    edited May 2012
    please keep us updated in your decission. love a good outcome.
    edited May 2012
    boston1450 wrote: »
    As Col. Hannible always says; "I love it when a plan comes together"
    edited May 2012
    Like Everyone else. Yes you will need a sub with Rti 12s .:cheesygrin:
    edited May 2012
    rebuy wrote: »
    Integrating a sub into a system is pretty fool-proof with all the room calibration built into AVR's these days. I always double check how audyssey sets my sub with an SPL meter, and its spot on every time.
    My System Showcase!
    Media Room
    Living-room
    Headphones
    edited May 2012
    To be honest. To make the 12's perform, at there best. You need a very good, high wattage, high current amp.
    Most HT receivers, are not up to the task. So i would have to say you need a sub for HT.
    For music, with the right power amp..you don't.
Welcome!
Welcome!
