If I switched to rti12's, would I still need my sub?
mva5580
mva5580 Posts: 75
edited May 2012 in Speakers
Right now I have (this is a 5.1 system) 2 rti10's for my fronts and a polk psw450 subwoofer. I switched to rti12 fronts, would I still need that psw450? Or would the 12's be capable of producing similar bass quality? I understand it won't be exact, but is it comparable?
Post edited by mva5580 on
  • B Run
    B Run Posts: 1,888
    edited May 2012
    You'll still want a sub, especially for movies. They'll produce a little more bass than your Rti10's but not a HUGE difference.
  • rebuy
    rebuy Posts: 695
    edited May 2012
    I would not run a sub with either one of those speaker choices. I like big full range speakers and a sub isn't always the best choice when going for a coherent sound. I know most on here will disagree but I don't care. Too many people get a powered sub and do not know how to balance it into a system thereby making the low octaves sound too fake for me.
  • B Run
    B Run Posts: 1,888
    edited May 2012
    I respectfully disagree on not needing a sub. I don't think the Rti12's have a ton of usable bass under about 45-50hz, and my sub plays to 18hz. If I didn't have it the bottom end would be missing and home theater experience would be very underwhelming. For music I could live without the sub but HT is a different story.
  • pearsall001
    pearsall001 Posts: 5,283
    edited May 2012
    Quick, simple answer....yes!
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited May 2012
    rebuy wrote: »
    C'mon, he's talking 5.1 HT... you like 5.0 better?? Clearly, you're referring to music.
    However, OP, want and need are two different things... Could you enjoy a movie without a sub? Yes. Do you want to??
  • mufsoman
    mufsoman Posts: 636
    edited May 2012
    Definate YES on needing the sub for HT. I would not run my Rti12's without the sub. Tried it and it aint no good.....
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime towers, center channel and bookshelfs (side surrounds)
    Atmos: Mirage Nanosats x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • Geoff4rfc
    Geoff4rfc Posts: 2,832
    edited May 2012
    Also a yes. I run equivalent speakers; RTiA9's and while they do put out some impressive bass, they don't come close to replacing my Empire!
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • boston1450
    boston1450 Posts: 7,758
    edited May 2012
    yup.....try it.....turn it off n try it......yup......you make the call....EDIT
    LET YOUR EARS DECIDE
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • jbooker82
    jbooker82 Posts: 1,627
    edited May 2012
    Upgrade and keep the sub.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    tonyb Posts: 33,072
    edited May 2012
    Well, lets keep in mind the OP's sub, the psw450. For movies you may want to keep the sub in the mix, for music though, I dunno man try it both ways and decide for yourself. The posters that say keep it, have way better subs than the 450. Let your own ears decide it's fate.
  • Dawgfish
    Dawgfish Posts: 2,554
    edited May 2012
    I would mostly agree that you probably need to still run a sub for HT for RTi-12s. I used to own a pair and actually ran a pair of DSW-PRO 600s with them for HT. There are always exceptions to the rule however. I tried bi-amping the RTi-12s for a bit sending 400 wpc to each RTi-12. I can tell you in this configuration there were many times were I turned off my subs and I never even noticed they were off, even in HT appliciations. I can tell you for a fact that given enough good clean power, RTi-12s can put out some seriously hard hitting and low bass.
  • mystik610
    mystik610 Posts: 699
    edited May 2012
    tonyb wrote: »
    Translation: Upgrade your fronts AND your sub:cheesygrin:
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • pearsall001
    edited May 2012
    mystik610 wrote: »
    Nah...your fronts are just fine, but once you upgrade the sub (better yet 2 subs) it's like magic happened to your system for both HT & 2 channel.
  • dekuda
    dekuda Posts: 756
    edited May 2012
    tonyb wrote: »
    Keep those 12's and look for another high quality sub and go with two subs. Then equalize everything( I recommend a antimode or velodyne sub equalizer if you can) . Sit back once you have two subs and change the front settings from large to small and back and let your ears make the choice. I did this and all I can say is it made a huge differance running the fronts at small and letting the subs handle everything 80hz and below. That being said, like Tony said it make a differance considering the sub(s). But those 12's are great fronts when powered correctly. I know this requires more upgrades but that is how it goes.......Just my 2 cents from my experiences.
    HT System
    Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
  • mdaudioguy
    edited May 2012
    ^^^ I don't think he has 12s, but rather 10s, which are still pretty cool, IMHO... :cool:
  • mantis
    mantis Posts: 17,365
    edited May 2012
    rebuy wrote: »
    Everyone everywhere in every system needs a sub if they want to recreate the playback material. Balancing it into a system isn't the question here.
    Dan
  • nhhiep
    nhhiep Posts: 877
    edited May 2012
    the rti12s have potential to put out good bass, then unlikely you will get there because u need to pump up the vol pretty high. I drive mine full range, but still send addition -60hz to the sub for music. For HT, you will NEED a sub regardless, otherwise u will miss the .1 channel.
  • boston1450
    edited May 2012
    please keep us updated in your decission. love a good outcome.
    Randy-Maine
    by David WMG
  • Geoff4rfc
    edited May 2012
    boston1450 wrote: »
    As Col. Hannible always says; "I love it when a plan comes together"
    Set up:
  • mwk455
    mwk455 Posts: 219
    edited May 2012
    Like Everyone else. Yes you will need a sub with Rti 12s .:cheesygrin:
  • mystik610
    edited May 2012
    rebuy wrote: »
    Integrating a sub into a system is pretty fool-proof with all the room calibration built into AVR's these days. I always double check how audyssey sets my sub with an SPL meter, and its spot on every time.
    My System Showcase!
    Media Room
    Living-room
    Headphones
  • naturallight
    naturallight Posts: 689
    edited May 2012
    To be honest. To make the 12's perform, at there best. You need a very good, high wattage, high current amp.
    Most HT receivers, are not up to the task. So i would have to say you need a sub for HT.
    For music, with the right power amp..you don't.
