SDA interconnects
nolasally
nolasally Posts: 4
edited May 2012 in Wanted (WTB) Classifieds
Also in need of female connectors that are in the backside of 2b's! Please help newbie. I am also an AKer!
Post edited by nolasally on
    Toolfan66 Posts: 18,121
    edited May 2012
    Please don't listen to that garbage above!!
    Buy a set of good binding post (one set) add one to each binding post cup and just by pass the pin blade outlet (leave the original outlet in there) then you can make your own interconnect cable with your favorite speaker wire using bananas on each end.
    You can also make your own AI-1 dreadnought, this way you can use non-common ground amps if you choose..
    Just my .02
    pitdogg2 Posts: 27,155
    edited May 2012
    Toolfan66 wrote: »
    Just my .02
    Listen to this guy... It's the right route
