Can someone with rtia3 provide a measurement?
Tmac06srt8
Tmac06srt8 Posts: 8
edited May 2012 in Speakers
Hello fellow Polk heads!
Looking to buy some rtia3's and a csia4 to start my ht setup.
I have a 55" panasonic plasma mounted above a corner fireplace and have limited space to the left and right of the tv. I want to mount via keyhole on rtia3's but only have about 6 inches and the website claims speakers are about 8.5 inches wide at the front. I understand the rti's taper and slim down though. Would someone be willing to provide a width measurement from the rear and about 4.5 inches from the rear of speaker?
I thank you in advance and will be joining the fam soon!
Cheers,
Post edited by Tmac06srt8 on
  • sandworms
    sandworms Posts: 1,043
    edited May 2012
    5 inches at the rear of the cabinet, this is as narrow as they get, at 4.5" it gets up to 7+ inches and 8.5 at their max
    welcome to the club
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • rebuy
    rebuy Posts: 695
    edited May 2012
    Here are the specs from the info page on these speakers.
    14 3/4" H x 8 7/16" W x 14" D
    (37.47cm H x 21.43cm W x 35.56cm D)
    It's under the product info.
    hope this helps.
  • Tmac06srt8
    Tmac06srt8 Posts: 8
    edited May 2012
    sandworms wrote: »
    welcome to the club
    Thank you! I am going to get the fxi4s next. Do you think I'll regret not getting the a6? I can get it for $50 more. I just don't want it to overpower the a3's.
    txcoastal1 Posts: 13,500
    edited May 2012
    Go with the "6" carries movie dialog and important for surround HT if you upgrade later and move the 3's to the rears it will be much better
    plus most receivers have adjustable levels per channel if you need to tame the center
    Enjoy and welcome to CP
  • B Run
    B Run Posts: 1,888
    edited May 2012
    txcoastal1 wrote: »
    +1! You won't regret it
  • Tmac06srt8
    Tmac06srt8 Posts: 8
    edited May 2012
    txcoastal1 wrote: »
    I am trying to keep it simple is the only reason I would go with the 4. I plan on mounting above tv and the depth of a4 is easier since I can get a stand for it like this. http://www.crutchfield.com/p_769CSB1210/Center-Stage-Bracket-CSB-1210-BLK.html?search=Tv+center
    The a6 i would have to recess which means cutting into wall. As you can see in my pic below, the space behind the tv is hollow so it may not be too hard.
