Can someone with rtia3 provide a measurement?
Tmac06srt8
Hello fellow Polk heads!
Looking to buy some rtia3's and a csia4 to start my ht setup.
I have a 55" panasonic plasma mounted above a corner fireplace and have limited space to the left and right of the tv. I want to mount via keyhole on rtia3's but only have about 6 inches and the website claims speakers are about 8.5 inches wide at the front. I understand the rti's taper and slim down though. Would someone be willing to provide a width measurement from the rear and about 4.5 inches from the rear of speaker?
I thank you in advance and will be joining the fam soon!
Cheers,
Cheers,
Post edited by Tmac06srt8 on
5 inches at the rear of the cabinet, this is as narrow as they get, at 4.5" it gets up to 7+ inches and 8.5 at their max
welcome to the clubSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Here are the specs from the info page on these speakers.
14 3/4" H x 8 7/16" W x 14" D
(37.47cm H x 21.43cm W x 35.56cm D)
It's under the product info.
hope this helps. -
welcome to the club
Thank you! I am going to get the fxi4s next. Do you think I'll regret not getting the a6? I can get it for $50 more. I just don't want it to overpower the a3's. -
Go with the "6" carries movie dialog and important for surround HT if you upgrade later and move the 3's to the rears it will be much better
plus most receivers have adjustable levels per channel if you need to tame the center
Enjoy and welcome to CP2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »Go with the "6" carries movie dialog and important for surround HT if you upgrade later and move the 3's to the rears it will be much better
+1! You won't regret it -
I am trying to keep it simple is the only reason I would go with the 4. I plan on mounting above tv and the depth of a4 is easier since I can get a stand for it like this. http://www.crutchfield.com/p_769CSB1210/Center-Stage-Bracket-CSB-1210-BLK.html?search=Tv+center
The a6 i would have to recess which means cutting into wall. As you can see in my pic below, the space behind the tv is hollow so it may not be too hard.
