Question about SDA Interconnect cable
dhart86
dhart86 Posts: 1,594
Hey guys...........I've been looking for a SDA pin/blade interconnect cable for my 1C's. I came across a polk original pin/blade with some type of transformer attached. Could someone tell me.....what's the deal with the transformer. Also, the cable is about 25 ft.......How much would you pay for that?
Any help would be appreciated.
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Post edited by dhart86 on
  • dhart86
    edited May 2012
    Main Rig:
    Second Rig:
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2012
    You can use non common ground amps with this. I'd pay $125-$150.
  • FTGV
    FTGV Posts: 3,650
    edited May 2012
    Put simply the transformer serves the purpose of allowing the use of amplifiers with bridged /balanced output stages (ie. non common ground) by isolating the negative speakers terminals of each channel from each other.
  • dhart86
    edited May 2012
    Thanks for your help leroyjr1 and FTGV. That helps me alot. I'm assuming it's OK to use a common ground amp with this cable as well.....Am I right?
    Main Rig:
    Second Rig:
    F1nut Posts: 51,913
    edited May 2012
    Yes it is, in fact some say that it sounds better using the AI-1 with a common ground amp than using the regular cable.
