common ground amp ??
ONEFLESH
What exactly is a "common ground amp".
Post edited by ONEFLESH on
Common Ground: An amplifier whose channels are all tied to a common ground (common electrical connection). This contrasts with an "isolated ground" amplifier where the ground of both channels is isolated from each other. An example of an isolated ground amplifier is a dual mono design.Proud and loyal citizen of the Digital Domain and Solid State Country!
Don't forget the "non-common ground amp" (my own name) which actually has different potentials (voltages) on the grounds such as certain "bridged" amplifiers. "Non-common ground amps" differ from "isolated ground amps" like mono blocks because there are actually voltages on the grounds with reference to earth ground instead of just being isolated from each other.
Is an amp with mechanically isolated tranformers a non common ground
i would assume soMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I smell something... a smell I have not sniffed for a very long time...
It smells like a rotted post!
This thread is a DECADE old! Probably will get more responses this thime through than it got the first time.:cheesygrin:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Hey if i don't find the previous post on a subject heiney starts actin' like a hiney.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I assume you mean two separate transformers in the same chassis in a dual mono configuration?That does not necessarily make it non common ground as it may use a non bridged output stages and have the negative speaker outputs of each ch connected to a common or star ground point.Thus making it common ground.Is an amp with mechanically isolated tranformers a non common ground
i would assume so
