Pin / Blade IC cable for SDA 1C speakers
dhart86
dhart86 Posts: 1,594
edited May 2012 in Wanted (WTB) Classifieds
I am looking for a pin / blade IC cable for my SDA 1C speaker. Let me know where I could get one.
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Post edited by dhart86 on
  • evhudsons
    evhudsons Posts: 1,175
    edited May 2012
    Time to make one, change up your connection, and unleash your 1c's SDA fury.
  • dhart86
    edited May 2012
    evhudsons wrote: »
    Some insight would be cool..........I'm not really sure how to do that!
    Main Rig:
    Second Rig:
  • evhudsons
    edited May 2012
    Oh, sorry about that! Here's some good links with even more links
    http://www.polkaudio.com/forums/archive/index.php/t-121856.html
    http://www.polkaudio.com/forums/showthread.php?30467-Improved-SDA-Interconnect-Cables
    http://www.polkaudio.com/forums/showthread.php?108598-My-custom-SDA-cable&
    http://www.google.com/search?hl=en&safe=off&client=safari&q=upgrade+sda+interconnect%2C+site%3Awww.polkaudio.com&oq=upgrade+sda+interconnect%2C+site%3Awww.polkaudio.com&aq=f&aqi=&aql=&gs_l=mobile-gws-serp.3...3978.8621.0.9528.13.13.0.0.0.1.572.2371.0j1j4j2j0j1.8.0...0.0.&mvs=0
    I haven't ordered the cardas binding posts yet. For a temp but effective quick upgrade i got a double sided binding post plate from home depot. It's in the home audio section. You just unscrew it from the plate, drill a hole in the Polk binding post area next to the sda jack, screw it back through and seal it. Then I just snipped off the sda wire connected to the pin portion and clamped it down in the inside. No soldering needed! Then I took 14 gauge speaker wire and capped each end off with banana plugs, one for each end. The negative and positive together so you have a bigger wire.
    The plate you get from home depot or wherever usually has more than one binding post but you only need two. So one package is more than enough.
    Simple, cheap, effective, and it really opens up more than you can imagine.
  • evhudsons
    edited May 2012
    This is about what I purchased:
    http://www.showmecables.com/product/Speaker-Wall-Plate-Decora-2-Binding-Posts-White.aspx
    This was just a temp job until I could get around to doing the nicer soldered job, but as it is in place and working fine I'm not in a hurry to change it. I used some silicon to seal the post in which is easily removable later. I also put a dab in the old sda jack to keep it airtight.
    You can get one made for you as well but bypassing the stock jack was easy enough. Try to get a good banana plug, you Only need two, one pair. They have them with screws so you don't have to solder those either. I used heat shrink wrap to make it more stable. Radio shed has them but so did home depot in the electric section. I'm limited in key west on stores available. I do online shopping but Home depot was quick and cheap. They have decent speaker wire, but get the fattest you can.
  • nspindel
    nspindel Posts: 5,343
    edited May 2012
    I've got a stock one that I can sell. No idea what they go for, anyone know?
    pitdogg2 Posts: 27,570
    edited May 2012
    I've seen 50.00 mostly for the P/B
  • nspindel
    edited May 2012
    Sounds fair to me. Dhart86, pm me if you want it, but don't wait too long - i'm leaving for London on Sunday, gone for two weeks.
  • dhart86
    edited May 2012
    evhudsons wrote: »
    Thanks for the info Evhudsons, not sure I'm up to the task. Don't want to mess the speakers up. I'll keep looking at the info to see if I can figure it all out!
    Main Rig:
    Second Rig:
  • fatso
    fatso Posts: 6
    edited May 2012
    I misplaced my cable when I moved. Made a new one it was easy using links provided. Then I found my original. Try it!
  • evhudsons
    edited May 2012
    At the least you can take speaker wire and twist it into the pin portion of each speaker until you figure it out.
