Pin / Blade IC cable for SDA 1C speakers
dhart86
I am looking for a pin / blade IC cable for my SDA 1C speaker. Let me know where I could get one.
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Second Rig:
Post edited by dhart86 on
Time to make one, change up your connection, and unleash your 1c's SDA fury.Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- sl9 surround backNHTsuper1's surroundMagnepan SMGParasound 1500pre- Sofia "Baby" tube amp - Monitor Audio Silver RX2 Marantz 2230/B&Kst140Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe
Some insight would be cool..........I'm not really sure how to do that!Main Rig:
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
Oh, sorry about that! Here's some good links with even more links
http://www.polkaudio.com/forums/archive/index.php/t-121856.html
http://www.polkaudio.com/forums/showthread.php?30467-Improved-SDA-Interconnect-Cables
http://www.polkaudio.com/forums/showthread.php?108598-My-custom-SDA-cable&
http://www.google.com/search?hl=en&safe=off&client=safari&q=upgrade+sda+interconnect%2C+site%3Awww.polkaudio.com&oq=upgrade+sda+interconnect%2C+site%3Awww.polkaudio.com&aq=f&aqi=&aql=&gs_l=mobile-gws-serp.3...3978.8621.0.9528.13.13.0.0.0.1.572.2371.0j1j4j2j0j1.8.0...0.0.&mvs=0
I haven't ordered the cardas binding posts yet. For a temp but effective quick upgrade i got a double sided binding post plate from home depot. It's in the home audio section. You just unscrew it from the plate, drill a hole in the Polk binding post area next to the sda jack, screw it back through and seal it. Then I just snipped off the sda wire connected to the pin portion and clamped it down in the inside. No soldering needed! Then I took 14 gauge speaker wire and capped each end off with banana plugs, one for each end. The negative and positive together so you have a bigger wire.
The plate you get from home depot or wherever usually has more than one binding post but you only need two. So one package is more than enough.
Simple, cheap, effective, and it really opens up more than you can imagine.Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- sl9 surround backNHTsuper1's surroundMagnepan SMGParasound 1500pre- Sofia "Baby" tube amp - Monitor Audio Silver RX2 Marantz 2230/B&Kst140Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe -
This is about what I purchased:
http://www.showmecables.com/product/Speaker-Wall-Plate-Decora-2-Binding-Posts-White.aspx
This was just a temp job until I could get around to doing the nicer soldered job, but as it is in place and working fine I'm not in a hurry to change it. I used some silicon to seal the post in which is easily removable later. I also put a dab in the old sda jack to keep it airtight.
You can get one made for you as well but bypassing the stock jack was easy enough. Try to get a good banana plug, you Only need two, one pair. They have them with screws so you don't have to solder those either. I used heat shrink wrap to make it more stable. Radio shed has them but so did home depot in the electric section. I'm limited in key west on stores available. I do online shopping but Home depot was quick and cheap. They have decent speaker wire, but get the fattest you can.Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- sl9 surround backNHTsuper1's surroundMagnepan SMGParasound 1500pre- Sofia "Baby" tube amp - Monitor Audio Silver RX2 Marantz 2230/B&Kst140Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe -
I've got a stock one that I can sell. No idea what they go for, anyone know?Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
I've seen 50.00 mostly for the P/B
Sounds fair to me. Dhart86, pm me if you want it, but don't wait too long - i'm leaving for London on Sunday, gone for two weeks.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Thanks for the info Evhudsons, not sure I'm up to the task. Don't want to mess the speakers up. I'll keep looking at the info to see if I can figure it all out!Main Rig:
Second Rig:
I misplaced my cable when I moved. Made a new one it was easy using links provided. Then I found my original. Try it!
At the least you can take speaker wire and twist it into the pin portion of each speaker until you figure it out.Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- sl9 surround backNHTsuper1's surroundMagnepan SMGParasound 1500pre- Sofia "Baby" tube amp - Monitor Audio Silver RX2 Marantz 2230/B&Kst140Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe
