Squeezebox Touch Experts-Help me out here
CSM41
CSM41 Posts: 55
edited April 2012 in 2 Channel Audio
I have a Squeezebox Touch hooked up with my Simaudio DAC via a coaxial cable. The SBT is hooked into my wireless router via cat5 and the router itself is hooked into my laptop via cat5. Now here is my problem. When I play a 24/192 .flac file the DAC only sees a 24/96 bitrate. I know the DAC isn't the problem because it switches well between other sampling rates. Does it not see 24/192 due to the cat5 connection between my router and laptop, or does the SBT not support 24/192 files? Or, is it a problem somewhere with the Windows 7 operating system? Any input is appreciated. See sig for my gear used.
#1 Pass F5/Dared Sl2000a/Nola Boxers/Basis Audio 1400/Audio Technica AT33EV Phono Cartridge/Cambridge Audio 640P-Hypno Modded/GF DAC09/CPU
#2 Cayin A-50T /Hornshoppe Horns/Squeeze Box Touch/Simaudio Moon 100D DAC/Rythmic F12 Servo Sub
Post edited by CSM41 on
    heiney9 Posts: 25,402
    edited April 2012
    Windows 7 has nothing to do with running the SQB. The SQB software runs the SQB. I would go to the Logitech SQB forums and see if other have this issue. If I had to make an educated guess without doing any research, perhaps the SQB or the SQB software only supports 24/96 bitrate and won't pass anything higher. You'll have to get your search on.
    edited April 2012
    Where did you get a 24/192 FLAC file?
  • CSM41
    CSM41 Posts: 55
    edited April 2012
    heiney9 wrote: »
    That was one of my thoughts also. I have bought all of my 24/192 albums from HD Tracks.
    edited April 2012
    Are you 100% sure they are actually 24/192? HD Tracks has been known to "overstate" some of their specifications. You really should go over the BB at SQB forums I'm sure this has come up before.
  • CSM41
    CSM41 Posts: 55
    edited April 2012
    It's funny you mention that. I have read the same thing about HD Tracks myself. Squeezebox shows them as 24/192, but I believe that is due to how they are tagged.
  • PrazVT
    PrazVT Posts: 1,607
    edited April 2012
    SB Touch only supports 24/96 max.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • CSM41
    CSM41 Posts: 55
    edited April 2012
    PrazVT wrote: »
    Even with an external DAC that supports up to 24/192?
  • coolsax
    coolsax Posts: 1,826
    edited April 2012
    yes, even with the external DAC b/c the touch stock, can't send it digitally at 24/192.. however Audiostream.com http://www.audiostream.com/content/get-usb-dac-and-24196-digital-output-your-squeezebox-touch made mention of a new app for the Touch that adds USB out functionality as well well as giving it 24/192, now i haven't tried the third party app, but its going to be the only way for it to send a 24/192 file.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • CSM41
    CSM41 Posts: 55
    edited April 2012
    OK, Got it. A fellow on the SBT Forum set me up with a file app that will allow the 24/192 files. Thanks, guys!
  • dragon1952
    dragon1952 Posts: 4,907
    edited April 2012
    What app is that?
  • dragon1952
    edited April 2012
    Cool...installed.....thanks!
