Kenwood KM-Z1 6 channel amp -THX certified-130wpc all channels driven - Atlanta Metro
rtart
Any interest in a Kenwood KM-Z1?
6 x 130wpc at 0.02%THD 8 ohms - ALL CHANNELS DRIVEN! It's THX certified, weighs 53 lbs. I've owned it for years and never had an issue. Clean power and cheap. Originally used it with the Kenwood THX controller, back when subs were all passive, (thus the 6th channel) and used with the whole THX certified Kenwood package of mains, subs and surrounds. I've long since sold all the other pieces, but kept the amp to use in my whole house audio system. Took it out when a local Polkie said he wanted it but backed out. In my closet for a year or so but works fine. I even have the original manual. Cosmetically its probably 8/10, but, did I mention cheap?
Sounds as good as the XPA-5 I had for a while (I did an A-B test for fun).
I say cheap, as in $150 plus shipping. I have amps running out my ears and could use the space.
My 7.4.4 DIY 4k Home Theater:
Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
Polk LSiM 702s x 4 on the Ceiling Atmos speakers
Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
Denon X3700H Emotiva XPA11 Gen 3
XBox One X 4k & BD and streaming
Panasonic UB-420 4k player
HD-A35 HD DVD
Oppo BD-103D for hirez audio
Technics SL-D2 TT, Grado Gold Cartridge
JVC DLA-RS2100/NZ7 projector
Silver Ticket 135" microperf AT screen
Berkline 090 electric recliners with Aura Bass Shakers
HD-A35 HD DVD
Post edited by rtart on
I have heard this amp and it actually doesnt sound as bad as people might think. If anyone wants a cheap way to bi amp your speakers, with a decent sounding amp, this would do the trick.
Thanks Ernie. I was never unhappy with it, and the specs are very good.My 7.4.4 DIY 4k Home Theater:
HD-A35 HD DVD
Berkline 090 electric recliners with Aura Bass Shakers -
PM Sent; waiting on original poster in WTB section to decide. Then I will see if it fits the bill for my brother's budget set-up.Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
PM replied!My 7.4.4 DIY 4k Home Theater:
HD-A35 HD DVD
Is it stable at 4 ohms? I could not find any specs on the web.
If its THX certified then yes, it should be stable down to 3.2 ohms I believe.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
PM sent.
The manual does not address 4 ohms but states 150 wpc at 6 ohms, 20Hz to 20kHz at 0.02%THD.My 7.4.4 DIY 4k Home Theater:
HD-A35 HD DVD
Sold to the first PM'er.
Thanks for the interest.My 7.4.4 DIY 4k Home Theater:
HD-A35 HD DVD
