Does length really matter?
Unknown
edited April 2012 in The Clubhouse
What is your opinion on the "length matters" debate?
IC's, Power cables. Digital cables????
Opinions?
A few examples of my "from scratch shorter cables".:cheesygrin:
Any input?
Long vs. short?
I would like to hear your thoughts.
You think it makes a difference?
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited April 2012
    It's all about width.
  • Systems
    Systems Posts: 14,872
    edited April 2012
    LMAO!
    I never thought about that!:cheesygrin:
    Testing
    Testing
    Testing
  • Systems
    edited April 2012
    These are all used cables, but luckily, my ole lady likes the SQ of the shorter ones!:cheesygrin:
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    edited April 2012
    According to the president of Wireworld, all WW power cords should be at least 2 meters long to take advantage of the additional filtering they offer.
  • Systems
    edited April 2012
    I'm not so sure.
    I have made probably made 100-125 power cables, and IMHO, a 4 footer would be my ideal.
    I recently tested this theory with a 4,5, 6 and 8.5 footer on hand.
    On my system at least, the 4 footer sounded better to me.
    The shortest cable I have made was 2 foot (dangerous:eek:) and alot of 3 footers.
    JMHO.
    Absolutely nothing scientific about it, just my ears, the 4 footer was better.
    I have just been doing alot length vs. awg cable tests recently, and was hoping to get some insight from other members, as far as SQ vs Length.
    Not sure if you have ever built a 10 foot pair of IC's from scratch, but just FYI, they sound different than a 2 foot pair.:cheesygrin:
    Can you tell a difference?
    2 foot, 3, 4 5 foot?
    Testing
    Testing
    Testing
  • chumlie
    chumlie Posts: 8,658
    edited April 2012
    Pep. I suggest you go to your bedroom system and try a double blind test. And post her results.
  • Systems
    edited April 2012
    chumlie wrote: »
    I likes da bedroom system!:lol::cheesygrin::eek:
    From 1 shelf up, to the next room.
    Rekon they sound different?
    The misconception being, people do NOT think they should/do sound different!
    That is my problem!
    Think these will sound as good as the 2 footers in the first pic?
    Testing
    Testing
    Testing
    EndersShadow Posts: 17,749
    edited April 2012
    I like 1.5 or 2m IC's simply because it gives me flexibility when moving gear around in my rack. I have had instances in the past where I couldnt put things where I wanted due to that.
    Plus depending on the cost of the IC's you are looking at, the last thing you want to do is drop 500 on some 1m IC's from someone like MIT and then have to get some 2m ones later on because you added more gear and cant make the 1m's work.
    As far as sounding different, well I dont have any super long cables (speaker, ic or power cables) to test against super short ones lol.
  • Systems
    edited April 2012
    That is a damn good point Dan.
    Naturally, I have thought about that in the past, but certainly, you would not expect them (except for the MIT's) to sound as good as a 2 foot pair of IC's?
    No?
    Testing
    Testing
    Testing
    edited April 2012
    For power cords, I really can't comment as I've only had 3 or 4 footers. IC's....shorter the better but like others said, you can shoot yourself in the foot when it comes time to moving gear around in the rack. As far as being audible between a 1m or 2m IC, not by my ears anyway.
    Bottom line.....don't sweat it and buy what suits your needs. If your switching gear around that often, you have other issues.
  • cstmar01
    cstmar01 Posts: 4,424
    edited April 2012
    Length always matters but it always takes so long to get where you want to go in a freight boat.
  • steveinaz
    steveinaz Posts: 19,546
    edited April 2012
    Since interconnecting cables are a necessary evil and yet another thing "in the way" of the signal, It's my opinion that shorter is always better.
  • falconcry72
    falconcry72 Posts: 3,580
    edited April 2012
    hey pep, as far as AWG for speaker cables, do you think there's a max size for carrying an audio signal, that beyond which you wouldn't gain an improvement?
    I have plans for a 7AWG cable in the works. 7 is double 10, for those who don't know.
  • BeefJerky
    BeefJerky Posts: 1,320
    edited April 2012
    Sure length matters, but it is not the only factor. The proper equation is:
    C= ((LxG)/(∠B)) / (M/W)
    This means that the conductivity factor of the cable is derived from:
    length times girth over the sharpness of the cable's bend (when put into use) divided by mass over width.
    pitdogg2 Posts: 27,772
    edited April 2012
    Personally I like mine to be just as long as needed. A friend has made some cables for me out of good Belden cable with Canare ends in 3' and the same in 18" using both i could tell no difference. On the other hand you also must consider the device you are hooking up. For instance this same friend went from TV to projector and his DVD player would not push a signal through a 50' component cable and at 25' it was bad at best but at 9' worked just fine. In the end he made extra long audio cables and made a stand for the DVD player to be closer to the projector. All cables were quality cables from Madisound. When he built his new theater room this was a lessen he kept in mind for the gear tower.
  • maximillian
    maximillian Posts: 2,149
    edited April 2012
    Mighty fine looking cables. Maybe it's just me, but I like the black ones better. Someday I'll try them out; hopefully not too stiff in my system.
    pepster wrote: »
  • Jstas
    Jstas Posts: 15,001
    edited April 2012
    Length and width (gauge) both matter because as you increase gauge and length, you increase resistance and that change in resistance affects your signal transfer. It doesn't "filter" anything, it just reduces strength and that cuts the strength of all signals in the path, not just the noise.
    In power cables, extra length helps with heat during peak draw because there is more material available to absorb heat. Therefore it takes longer for the power cord to heat up to an unsafe point.
    Expert Moron Extraordinaire
  • sucks2beme
    sucks2beme Posts: 5,701
    edited April 2012
    Most DAC makers want you to use the shortest USB cable you can.
    As far as other cables go, my rule is always shorter is better.
    Longer power cables are better for heat? No, shorter and bigger gauge is better.
    Lower resistance means less power is turned to heat in the cable and more of it is
    delivered to the device.
  • BlueFox
    BlueFox Posts: 15,250
    edited April 2012
    So far, all we are getting is opinion. Here is one more.
    The length, along with other characteristics, will affect the signal. Depending upon the gear at either end of the cable, there may, or may not be, an effect. It would seem to be possible that in some situations a longer cable could be 'better' than a shorter cable. Other situations could be reversed.
  • sucks2beme
    edited April 2012
    In the real world, shorter is always better. Electronics 101.
    Digital cables- shorter = better.
    If your are using an analog cable to change the sound with it's impedance
    whole other story. That where all the arguments start.
  • Drenis
    Drenis Posts: 2,871
    edited April 2012
    sucks2beme wrote: »
    Hmm... I have heard some differing opinions about that. See quote below:
    Anything else in a digital cable I would recommend going with a 1.5m length.
    It eliminates digital reflections caused by timing issues.
    You can tell a difference.
    Matter of fact, the person who stated this quote has posted in this thread.
  • steveinaz
    edited April 2012
    sucks2beme wrote: »
    EXACTLY. The truth of the matter (not opinion) is any cable between 2 pieces of equipment is a deficit; so logic would dictate that shorter is always better. Now, if you're attempting to "manipulate" the original signal....there ya go.
  • steveinaz
    edited April 2012
    Drenis wrote: »
    This depends on the receiver/sender interface quality of the equipment, and it's adherence to the 75ohm standard--and is still VERY debatable. You'll hear arguments on both sides on this topic.
    Some "experts" claim that your speaker cables should be at least 8 feet in length as well---I think they just need different speakers. Hi-fi is all about eliminating weak links, cables are weak links, regardless of quality, topolgy, and/or length.
  • codyc1ark
    codyc1ark Posts: 2,539
    edited April 2012
    Whats the length of a wire coat hanger after you've undone it and made it straight? About 2 feet or so? Sometimes they break when undoing them at the top, so, whatever length my coathangers are...
  • steveinaz
    edited April 2012
    plastic or metal?
  • codyc1ark
    edited April 2012
    steveinaz wrote: »
    plastic or metal?
    Metal, with a plastic coating for shielding of course!! :cheesygrin:
  • cincycat13
    cincycat13 Posts: 887
    edited April 2012
    I do feel that length matters. If the cable is too SHORT to connect my equipment together...it seems like I can't hear any sound.
  • Jstas
    Jstas Posts: 15,001
    edited April 2012
    BlueFox wrote: »
    Opinion?
    Man, you're daft!
    Physics dictates that length and gauge matter. It can be proven with actual math. It's not opinion. It is actual, proven, scientific fact.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited April 2012
    Jstas wrote: »
    Increasing gauge size actually reduces resistance when compared to cables of same length. The added material flows easier. I guess the longer power cord would take longer to heat up, but a larger/shorter cord with less resistance, eliminates the heat too.
    Did I misunderstand your take, John and you actually want us to use very small, very long power cords? I think you have it backwards.
  • Jstas
    Jstas Posts: 15,001
    edited April 2012
    If you increase gauge and your performance increases, your previous wires were too small.
    You can have a gauge that is too large and will increase resistance.
    Don't be a smartass. If you don't believe me, you can look up yourself. There are formulas you can use to determine the gauge of wire you need for a certain application. This isn't wire mumbo-jumbo and "hearing is believing" and all that other BS.
    In fact, since you want to "educate" me and mock me because you don't understand, here, learn something:
    http://www.allaboutcircuits.com/vol_1/chpt_12/5.html
    You can get your education for free. It cost me $1600+ a term to learn it in Circuits I 15 years ago
    This one explains the equations: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/resis.html
