A good product for cleaning electronics
Sherardp
I will usually break out my swifter for dusting, but saw these dry cloths from Windex and decided to give them a shot. I used them to clean up my 27"Imac, the 60 inch plasma and other components. I will say they work very well, without leaving those annoying streaks behind. Give these a go, you maybe able to find them cheaper.
http://www.amazon.com/Windex-Electronics-Cloths-12-Count-Pack/dp/B004GCSMJ4
Post edited by Sherardp on
Thanks for the link, I'll be sure to check these out.
Right now I just use a swiffer and it works good.
Once a year, I'll take the cover off all my electronics and use a vacuum cleaner for the insides.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
I use them all the time and like them alot.No lint,no scratch.
You reminded me that i need to order some more.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!!
