A good product for cleaning electronics
Sherardp
Sherardp Posts: 8,038
edited April 2012 in The Clubhouse
I will usually break out my swifter for dusting, but saw these dry cloths from Windex and decided to give them a shot. I used them to clean up my 27"Imac, the 60 inch plasma and other components. I will say they work very well, without leaving those annoying streaks behind. Give these a go, you maybe able to find them cheaper.
http://www.amazon.com/Windex-Electronics-Cloths-12-Count-Pack/dp/B004GCSMJ4
Post edited by Sherardp on
  • Serendipity
    Serendipity Posts: 6,975
    edited April 2012
    Thanks for the link, I'll be sure to check these out.
    Right now I just use a swiffer and it works good.
    Once a year, I'll take the cover off all my electronics and use a vacuum cleaner for the insides.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • brgman
    brgman Posts: 2,859
    edited April 2012
    I use them all the time and like them alot.No lint,no scratch.
    You reminded me that i need to order some more.
    I’M OFFENDED!!!!
