What SDA2's are these? Worth $275?
Nevermind, I see now that the SDA-2b's are 6 ohms.Mike
Pioneer SC-05 Receiver
Polk SDA-2b
Polk RTA 11TL w/RDO-198's
Polk RT25i Satelite Speakers
Polk CS 400 Center Speaker
Polk PSW 350 Sub Woofer
Samsung 46" 1080p LCD TV -
Will the Pioneer SC-05 be able to power the SDA2b's? I was looking at the specs on the SC and it doesn't show that it is 4 ohm capable? Should I be looking for an amp that is 4 ohm capable? This hobby is starting to get out of hand (not too bad though). In the last year I've bought more audio equipment than I have in the last 20 years. Next thing you know it will be as bad as my motorcycle habit. I have 11 of those right now. Back to the SC, Whatcha think?
The Pioneer SC-05 should be able to handle the SDA 2B's just fine, provided you don't get crazy on the volume knob. But, if you like to really crank them from time to time, consider getting a separate amp so you don't have to sweat it.
