Avia vs. DVE calibration dvds
kevhed72
kevhed72 Posts: 5,126
edited April 2012 in Electronics
I figured it is time to actually buy one of these for my PJ....anyone recommend or use the following?
http://www.amazon.com/Avia-II-Artist-Not-Provided/dp/B000X4NJNS
(I noticed the DVE disc is a bit cheaper...)
Post edited by kevhed72 on
  • Conradicles
    Conradicles Posts: 6,324
    edited April 2012
    I have used them both and liked both. Did that help? (lol)
    DVE was a bit better but not by much...
  • kuntasensei
    kuntasensei Posts: 3,263
    edited April 2012
    If you're just doing video, either will do. If you're doing audio too, avoid DVE like the plague. The test tones aren't digitally correct.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • kevhed72
    edited April 2012
    I just received the Avia DVD and gave it a try...what was your take / experience adjusting the CONTRAST? I found the explanation and test pattern for contrast very....subjective....if that makes sense. All the other standard settings so far were pretty easy to determine, but not contrast....
    tonyb Posts: 33,065
    edited April 2012
    You can also just google search for some pro settings. Sometimes pro techs will list certain TV's settings that they normally would use or have used. Did that with mine and they were pretty spot on.
