Avia vs. DVE calibration dvds
kevhed72
I figured it is time to actually buy one of these for my PJ....anyone recommend or use the following?
http://www.amazon.com/Avia-II-Artist-Not-Provided/dp/B000X4NJNS
(I noticed the DVE disc is a bit cheaper...)
Post edited by kevhed72 on
I have used them both and liked both. Did that help? (lol)
DVE was a bit better but not by much... -
If you're just doing video, either will do. If you're doing audio too, avoid DVE like the plague. The test tones aren't digitally correct.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Conradicles wrote: »I have used them both and liked both. Did that help? (lol)
I just received the Avia DVD and gave it a try...what was your take / experience adjusting the CONTRAST? I found the explanation and test pattern for contrast very....subjective....if that makes sense. All the other standard settings so far were pretty easy to determine, but not contrast.... -
You can also just google search for some pro settings. Sometimes pro techs will list certain TV's settings that they normally would use or have used. Did that with mine and they were pretty spot on.HT SYSTEM-
