DTS vs DD
AsSiMiLaTeD
To my ears, DTS soundtracks are more enveloping than DD.
DTS has a higher sampling rate which makes is better. If used to its full potential DTS will sound better. Just think of when you make MP3's, a 192 MP3 sounds better than a 128 MP3 because of the higher sampling rate.
Regards,
PolkThug -
why arent there more DTS movies? to save space on the dvd? i'd much rather have a DTS soundtrack then all that extra **** that i dont watch.
Amen! I just picked up the Superbit copy of Vertical Limit and the DTS soundtrack is beyond belief, not to mention the improved video. Watching it on the FP is amazing!Originally posted by Airplay355
i'd much rather have a DTS soundtrack then all that extra **** that i dont watch. -
Yes. Look for Superbit titles. I just made my own Superbit Undercover Brother, I stripped out all the menus and dolby crap and made it just video and DTS.
Regards,
PolkThug -
PM -- Exactly how did you do that???HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
DTS, hands down.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
DTS floats mah boat!
shhhhh...don't tell the wife:rolleyes:"she had the body of Venus, with arms." -
i've been partial to DTS ever since i got into buying DVD's. i think the sound in DTS has better dynamics overall. nothing wrong with DD of course.. but if a DVD has both tracks. i'll always choose the DTS soundtrack over the DDPolkFest 2012, who's going>?
ditto danger boy's commentsMains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688 -
dts all the way. the sourround effects always seem to be much more pronounced.Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
I FIND THE DTS SOUNDTRACKS MUCH RICHER AND FULLER IN SOUND, THE SURROUND EFFECTS SEEM TO ME TO BE MUCH MORE PRONOUCED . IF YOURE INTO CONCERT DVD'S AT ALL DTS MAKES YOU FEEL LIKE YOURE RIGHT THERE .
There are several good DD tracks out there, very good actually. However, when it comes down to discs with a choice, DTS is always the winner to me.
well that's pretty much unanimous...
so why aren't mroe DVDs mastered in DTS? -
What percentage of DVD players out there will decode DTS?
Who uses their DVD player to decode anymore? Good question...Originally posted by Shizelbs
Every player I've owned does DTS... -
a DVD player will only pass thru the DTS signal.. your receiver/preamp does the decoding for ya. it's all so magical. i don't know how it does it. it just does.
there are probably little tiny men in each unit. and they switch it between DD and DTS. waaaaaaaaaaaaa!PolkFest 2012, who's going>?
Are there not DVD players that let you send a line out for each speaker once the DVD player does the decoding?
yeah but i think that may be only for DD. and they are 5.1 analog RCA connectors. most of todays new model DVD players no longer have those 6 analog RCA connectors. unless you go to the higher end stuff. those used to be standard on most any dvd player. till a few years ago when the $49 DVD hit the Wal Marts of the world.PolkFest 2012, who's going>?
I'm guessing that a lot of people when buying a new DVD player, naively ask the salesman if it has DD. I think its become a buzzword selling point for DVD players and DVDs. Perhaps dts does not have that buzzworthy recognition yet.
DTS by a far margin. Better envelopment, panning, and integration.
I used to think DTS always sounded better, but with my current setup DD seems better. DD has a higher volume output (switching to DTS lowers the volume for some reason), and has a greater bass impact. My current DVD player, although expensive, only has a DTS digital out, not a built-in decoder. Could this be the reason? My receiver is of high quality and DTS sounds great, but better? Not quite. I know it should though.
(Accidentally posted this as a new thread rather than reply, so sorry if this is redundant).Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
gregure,
i don't think ANY dvd players have a DTS decoder in em.. only a Dolby Digital decoder.
DVD players only pass thru the DTS signal and it is then decoded by your receiver.
i could be wrong about this.. but i'd be surprised if a DVD player had a DTS decoder built into it.
the digital connector whether it be optical or coaxial will work for both Dolby Digital and as a pass thru of the DTS signal.
My Panasonic DVDP has built in DD and DTS processors. There are several that do actually, at least last time I looked.
Cheers,
Yep, mine too.
DV-47a specs
There are tons of players are DTS capable, those simply pass the signal to a receiver/preamp/external decoder. Generally the players a little farther up the ladder will have a decoder built in. As long as the processor you're using has quality DAC's, then it shouldn't make too much of a difference. -
Russ, which model of Panasonic DVDP do you have?PolkFest 2012, who's going>?
Can anyone cite a movie that they thought sounded better in DD than dts?
