Little ruber feet.......
Just curious, How many people use the little rubber feet that come with some of the centers and surround speakers?
I just got my LSiC, and wondered if any one actually uses these feet.
Are there any advantages?
Are there any reasons not to use them?
Polk LSi 15 Fronts
Polk LSi C center
Polk LSiFX Surrounds
Outlaw Audio 990 Pre/Pro
Outlaw Audio 755 amp
Paradigm PDR-12 Sub
Outlaw Audio Cables
BetterCables Cables
Polk LSi C center
Paradigm PDR-12 Sub
Outlaw Audio Cables
BetterCables Cables
I use the little rubber feet on my center and surrounds. I only do it to keep them from falling off the stands and TV.
They do provide decoupling (sp) to the surface the speaker is placed upon, I would assume.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
I heard an improvement especially the bass when I used the plastic feet between my LSi9 and speaker stands. The ones on the speaker stands were too soft and thin.
Maurice -
i use mine just because i dont wanna scratch my cabs or leave black marks on the wall
Sounds like most people use the little rubber feet.
What benefit does the decoupling provide?
just wonderedPolk LSi 15 Fronts
Polk LSi C center
Paradigm PDR-12 Sub
Outlaw Audio Cables
BetterCables Cables -
Decoupling can reduce or eliminate unwanted resonances and vibrations that can be transferred to the speaker stands or whatever the speaker is set on.
I use the rubber feet. They are easy to take off if you need to and the adhesive can also be removed at a later date if needed.
No harm no foul here. -
i use mine too. keeps the center from moving around it things get to rough and loud.PolkFest 2012, who's going>?
LOL! I can just see the speaker vibrating off the top of the TV like an alarm clock going off!
2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
sunfire subs like to do that, as well as my b&w lol
I use the rubber feet! The center I use it to tilt the center down to the listening position. I doubled the rear & use single in the front. Easy way of directing the speaker angle.
June 10th?
Ha that's mine.................... -
I put my rubber bumpers on the corners of my speaker stand so as to not ruin the finish on my speakers. They definitely help absorb extraneous speaker vibrations.
