Little ruber feet.......
nemos2
nemos2 Posts: 111
edited April 2004 in Speakers
Just curious, How many people use the little rubber feet that come with some of the centers and surround speakers?
I just got my LSiC, and wondered if any one actually uses these feet.
Are there any advantages?
Are there any reasons not to use them?
Polk LSi 15 Fronts
Polk LSi C center
Polk LSiFX Surrounds
Outlaw Audio 990 Pre/Pro
Outlaw Audio 755 amp
Paradigm PDR-12 Sub
Outlaw Audio Cables
BetterCables Cables
  • Shizelbs
    Shizelbs Posts: 7,433
    edited April 2004
    I use the little rubber feet on my center and surrounds. I only do it to keep them from falling off the stands and TV.
  • gatemplin
    gatemplin Posts: 1,595
    edited April 2004
    I use them so my speakers dont get scratched up.
    Graham
  • dragon1952
    dragon1952 Posts: 4,943
    edited April 2004
    They do provide decoupling (sp) to the surface the speaker is placed upon, I would assume.
  • organ
    organ Posts: 4,969
    edited April 2004
    I heard an improvement especially the bass when I used the plastic feet between my LSi9 and speaker stands. The ones on the speaker stands were too soft and thin.
    Maurice
  • Airplay355
    Airplay355 Posts: 4,298
    edited April 2004
    i use mine just because i dont wanna scratch my cabs or leave black marks on the wall
  • nemos2
    nemos2 Posts: 111
    edited April 2004
    Sounds like most people use the little rubber feet.
    What benefit does the decoupling provide?
    just wondered
    Polk LSi 15 Fronts
    Polk LSi C center
    Paradigm PDR-12 Sub
    Outlaw Audio Cables
    BetterCables Cables
  • pjdami
    pjdami Posts: 1,894
    edited April 2004
    Decoupling can reduce or eliminate unwanted resonances and vibrations that can be transferred to the speaker stands or whatever the speaker is set on.
    I use the rubber feet. They are easy to take off if you need to and the adhesive can also be removed at a later date if needed.
    No harm no foul here.
  • danger boy
    danger boy Posts: 15,722
    edited April 2004
    i use mine too. keeps the center from moving around it things get to rough and loud.
    PolkFest 2012, who's going>?
  • dragon1952
    edited April 2004
    LOL! I can just see the speaker vibrating off the top of the TV like an alarm clock going off! :p
  • Airplay355
    edited April 2004
    sunfire subs like to do that, as well as my b&w lol
  • ezc
    ezc Posts: 426
    edited April 2004
    I use the rubber feet! The center I use it to tilt the center down to the listening position. I doubled the rear & use single in the front. Easy way of directing the speaker angle.
  • mingram1234
    mingram1234 Posts: 31
    edited April 2004
    June 10th?
    Ha that's mine....................
  • Shell
    Shell Posts: 134
    edited April 2004
    I put my rubber bumpers on the corners of my speaker stand so as to not ruin the finish on my speakers. They definitely help absorb extraneous speaker vibrations.
