bi amp rti 150s and optimization mic
hiphopfeinds
i have a Yamaha htr 5760 receiver and a set of polks rti 150 cani bi amp these to the speaker set B? and also when i bought the receiver it didnt come with the optimization microphone how much better will this make my system sound?
No, that's not bi-amping.
Much better. In lieu of the mic, you can use an SPL meter.Political Correctness'.........defined
President of Club Polk -
I think i have them bi amped but im not sure. i did what i said in the original post. I removed the gold things from the back of the rti 150 that link the 2 terminals together. I then connected a wire from speaker set A right speaker out to the bottom connections. then ran another wire from speaker set B right to the top terminals connection. On the reciver i played with it by starting with both sets A and B off then turning on A then B the top terminal set seems like it was for highs and the bottom was for the bass. It seems like it worked and was pretty loud. i didnt have enough wire so i just used my left fronts wire. so now i gotta decide if i like it so i can buy a few more feet of wire. -
I understand what you have done and it is NOT bi-amping. What you have done is basically bi-wiring.
Instead of bi-anything try this, connect the speaker set A to the bottom posts of the speakers. Then use a short piece of the speaker cable to replace the stock jumpers connecting the top and bottom posts. Done, relax and enjoy.Political Correctness'.........defined
i dont see how that would be better, but then i might be wrong but having them bi wired they seem to sound better and louder!I understand what you have done and it is NOT bi-amping. What you have done is basically bi-wiring.
Instead of bi-anything try this, connect the speaker set A to the bottom posts of the speakers. Then use a short piece of the speaker cable to replace the stock jumpers connecting the top and bottom posts. Done, relax and enjoy. -
hiphopfeinds wrote: »i dont see how that would be better, but then i might be wrong but having them bi wired they seem to sound better and louder!
When biamping with an AVR all you are doing is stretching across the same amplifier source
So its not biamping, hence the prefix bi=22-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Well, you only have one speaker sort of bi-wired, which you thought was bi-amping and since you said you needed to buy more speaker wire the method I suggested will get you the same result without having to buy more cable. It may even sound better than the sort of bi-wiring as you'll have a lot less speaker cable exposed to picking up RF/EMI.Political Correctness'.........defined
