bi amp rti 150s and optimization mic
hiphopfeinds
hiphopfeinds Posts: 10
i have a Yamaha htr 5760 receiver and a set of polks rti 150 cani bi amp these to the speaker set B? and also when i bought the receiver it didnt come with the optimization microphone how much better will this make my system sound?
    F1nut Posts: 52,356
    edited April 2012
    No, that's not bi-amping.
    Much better. In lieu of the mic, you can use an SPL meter.
  • hiphopfeinds
    edited April 2012
    I think i have them bi amped but im not sure. i did what i said in the original post. I removed the gold things from the back of the rti 150 that link the 2 terminals together. I then connected a wire from speaker set A right speaker out to the bottom connections. then ran another wire from speaker set B right to the top terminals connection. On the reciver i played with it by starting with both sets A and B off then turning on A then B the top terminal set seems like it was for highs and the bottom was for the bass. It seems like it worked and was pretty loud. i didnt have enough wire so i just used my left fronts wire. so now i gotta decide if i like it so i can buy a few more feet of wire.
    F1nut Posts: 52,356
    edited April 2012
    I understand what you have done and it is NOT bi-amping. What you have done is basically bi-wiring.
    Instead of bi-anything try this, connect the speaker set A to the bottom posts of the speakers. Then use a short piece of the speaker cable to replace the stock jumpers connecting the top and bottom posts. Done, relax and enjoy.
  • hiphopfeinds
    edited April 2012
    i dont see how that would be better, but then i might be wrong but having them bi wired they seem to sound better and louder!
    txcoastal1 Posts: 13,520
    edited April 2012
    When biamping with an AVR all you are doing is stretching across the same amplifier source
    So its not biamping, hence the prefix bi=2
    F1nut Posts: 52,356
    edited April 2012
    Well, you only have one speaker sort of bi-wired, which you thought was bi-amping and since you said you needed to buy more speaker wire the method I suggested will get you the same result without having to buy more cable. It may even sound better than the sort of bi-wiring as you'll have a lot less speaker cable exposed to picking up RF/EMI.
