Pa d1000.1
SDA1C
SDA1C Posts: 2,072
edited April 2012 in Car Audio & Electronics
Has anyone tried the PA D1000.1 on a set of sealed 12" kickers in parallel?
Too much **** to list....
Post edited by SDA1C on
  • arun1963
    arun1963 Posts: 1,797
    edited April 2012
    The PA D1000.1 is stable down to 1 ohm. If the Kickers are DVC then you can then you can set the VC on each sub to a 2ohm load and then connect them in parallel to get a 1 ohm load overall and 1200 watts to the subs. 600 watts to each will be plenty. If the subs are SVC then connected in parallel they will show a 2ohm load and each sub will get 400 watts, which is also fine.
  • exalted512
    exalted512 Posts: 10,734
    edited April 2012
    There are at least 20 different kicker sub configurations...which one are you referring to?
    -Cody
  • SDA1C
    SDA1C Posts: 2,072
    edited April 2012
    exalted512 wrote: »
    -Cody
    Any. I haven't bought them yet. I am looking for any word on which setup would be best. The smaller the box the better. I want to try the D1000 is about as far as I have gotten.
  • exalted512
    edited April 2012
    then why kicker specifically?
    -Cody
